Spark Plug makers say no anti-seize
Discussion in '1st Gen. Tacomas (1995-2004)' started by Turp, Sep 3, 2011.
  1. Sep 3, 2011 at 2:03 PM
    Turp
    Turp [OP] Well-Known Member
    Virginia
    02 PreRunner SR5
    K&N panel/ snorkel removed Keyless, 2022 4Runner Wheels
    Found this reading and curious what you think.
    I like the idea of anti-seize but also understand what NGK states.
    http://www.ngksparkplugs.com/pdf/TB-0630111antisieze.pdf
    and they weren't the only company. Denso, AC/Delco and Autolite were cited on other forums.
    I guess for me, it's reminder to be careful of the torque and maybe reduce it it I use a antiseize.
    Any thoughts or experience?
  2. Sep 3, 2011 at 2:11 PM
    SlurpeeBlueMetallic
    SlurpeeBlueMetallic FFFFFFUUUUUUUUUUUUUUU...
    Interesting...
    So the main issue, according to the article, is the anti-seize allowing you to over-torque the plugs. I always use a good torque wrench and will keep using my anti-seize :D
    Most folks use way too much of the stuff anyway. The last pictures in the linked article show more than twice as much on that plug as I normally use.
  3. Sep 3, 2011 at 6:00 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Anti sieze type thread dressings are never a good idea with threads/bolts that make a sealing surface , not just get tight, spark plugs don't require a great amount of torque to seal & stay tight by design, just like oil filters, just wet the gasket & run it down til it makes contact with surface & 1/4 turn, done with no leaks, no loosening...;)
    Markcal likes this.
  4. Sep 3, 2011 at 9:49 PM
    00yotasr5
    00yotasr5 Well-Known Member
    lee
    merced, ca
    00 SR5 4X4 RED DEVIL
    Icon ext travel expo leafs rear billies 5125 10'' travel bamf bpv relocate Brute Force Fab Sliders allpro ss brake lines f/r LR UCA 22in wetokled bar RAT Products ifs skid ARB rear locker Ultra gauge Redline Hood Struts Blue Sea Fuse box smittybilt xrc 9.5 w/TJM synthetic rope trail-gear rock assault low profile bumper LED bed strip 12v/usb charger in truck bed
    dont believe in anti-sieze
  5. Sep 3, 2011 at 10:14 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    Interesting... Considering the dissimilar metal bond exasperated by an electrical medium.
    I always use anti seize and have never had a problem with spark plugs breaking. If torqued to the right torque with or without anti seize you should not have a problem however the aluminum heads and steel plugs will corrode and cause a bond. Unless you want to drop the dime to get new heads on your truck which for one side of a 5VZ-FE by dealer is $2,400 then by all means...
    Look up the term "Galvanic Corrosion"
    Yetimetchkangmi and Krazie Sj like this.
  6. Sep 3, 2011 at 10:22 PM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    Torquing spark plugs?
    Who the hell does that..I tighten till snug, then 1/3 turn and done.
    Torquing is not needed on anything except for wheels IMO..I've never had ANY problems. :cool:
    That's just me though..and I'm me. ;)
    2000TRDTaco likes this.
  7. Sep 3, 2011 at 10:30 PM
    scocar
    scocar hypotenoper
    Krazie Sj likes this.
  8. Sep 3, 2011 at 10:32 PM
    scocar
    scocar hypotenoper
    Boy, all those metallurgists, engineers, and manual writers sure have been wasting their time on useless details. You should give them a call.
    austin2009 likes this.
  9. Sep 3, 2011 at 10:32 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    This ^^^^
    Ive seen too many siezed plugs in aluminum heads. As long as you dont goop the anti sieze on the plug (use a very small film), you will be just fine. In lawn mowers, older vehicles, or any iron block/head engine, Yes, you dont use anti sieze.
    txtaco87 likes this.
  10. Sep 3, 2011 at 10:43 PM
    UndefinedTaco
    Justin
    Tracy, CA
    Toyota
    Good plan, I'll get on that on Monday.
    I mean Tuesday, since they are probably off Monday.
    :cool:
  11. Sep 4, 2011 at 7:29 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    I put a small amount on the threads and always will, I use a torque wrench too!
    Obsessed2000 likes this.
  12. Sep 4, 2011 at 8:55 AM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    X2.
  13. Sep 4, 2011 at 9:59 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    pretty sure that the threads in the heads (hey a rhyme) arent aluminum & all the technical mumbo jumbo is really just a name for electrolysis. If you tighten your plugs too much what happens is from constant heating/cooling (expansion & contraction) the threads start to cavitate & collapse on each other making the plug seem more like part of the head instead of a part FOR the head....
  14. Sep 4, 2011 at 10:04 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The threads in the 3.4, and the 4.0 are aluminum. THey have no steel inserts.
  15. Sep 4, 2011 at 10:13 AM
    Buggys3sgte
    Buggys3sgte Well-Known Member
    Psycho state of AZ
    97 BUDGET Taco
    Newly rearranged front end, sick Hurst shifter yo gives it lightning fast shifts, thats it more to come.
    Good luck in the future rebuilding a motor son ;).
    A little anti seize won't hurt but like anything too much of something isn't good. Reason why the new vehicles bond is because the plugs now days are run for longer amounts of time before they are changed out for new ones. Iridiums will out last copper core plugs by 60-80k if your ride is in good working order hence the price difference between the two. For all those guys that don't like anti-seize obviously you haven't dealt with rusted corroded bolts on exhuast manifolds before, buy a 20 year old forced induction ride and then get back to me.
    Blais03 likes this.
  16. Sep 4, 2011 at 10:15 AM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    Interesting find. I agree though, the example pictures are way more than I use, and I try to smear it into the groves before putting them in.
  17. Sep 4, 2011 at 10:17 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    no shit huh, that doesn't seem to be the best setup to me but I digress, I recently changed my plugs (with the dreaded BOSCH plugs, no issues at all with them, starts fine ,runs great) & removal was also a non event, go figure...
  18. Sep 4, 2011 at 10:25 AM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    They didn't say to NEVER use anti sieze - only that it isn't required on SOME spark plugs but IS required on others....
    Summary
    All spark plugs that have a blackened or dull appearance on the metal body offer no protection against seizing or bonding to the cylinder head and so it is with these spark plugs that anti-seize would be required. A spark plug that has a shiny silver appearance on the metal body usually indicates that the
    plug is manufactured with metal shell plating and therefore will not require anti-seize.
    armyofsquirrels likes this.
  19. Sep 4, 2011 at 11:42 AM
    scocar
    scocar hypotenoper
    And this is a good point. I actually prefer some not-long-lasting things in some applications, and spark plugs is one of them. I mean, isn't 30,000 miles a long enough interval to take a peak at your burn and simultaneously yank the plugs before any corrosion can get well-established...
    I would think the same with diffs and using non-synth. A good time to inspect for shiny bits and compromised oil from immersion/leaks.
    ThunderOne and armyofsquirrels like this.
  20. Sep 13, 2011 at 10:23 AM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    Ahh! More debate on anti-seize. I've been working on cars, power equipment, and general stuff for 40 years and swear by anti-seize. It allows for correct torquing of nuts, bolts, and plugs. It does NOT cause the thread to loosen. The active material in anti-seize is a soft metal powder or synthetic. This acts as a slip barrier so the parts will not bind when installed and hold tight when torqued. Most important it allows for removal when necessary because it stops corrosion. In all my years of cranking a wrench on various pieces of equipment I can't recall anything coming lose because of anti-seize. I can't even imagine not using it on something as soft as aluminum threads with a steel spark plug. I don't care what the plug manufacture says.
    tomrad, 68dave and fireman1073 like this.
