Spark plug power loss,please help!!!
Discussion in 'Performance and Tuning' started by TACOsupremacy, May 5, 2012.
  1. May 5, 2012 at 9:23 PM
    TACOsupremacy
    TACOsupremacy [OP] Well-Known Member
    Gaven
    Aiea_Hawaii
    05taco
    Never satisfied
    So i changed my plugs a couple of days ago (denso) everything else is fine but when im driving at a constant speed, my truck suddenly jus loses power. But not to the point where it dies out, more like short glitches like i have a vacum leak or something. I checked everything and no vacum leak or anything. Maybe i should recheck if the ignition coils are on better?? or is something jus wrong??
  2. May 5, 2012 at 9:35 PM
    TACOsupremacy
    Gaven
    Aiea_Hawaii
    05taco
    Never satisfied
    Pretty much almost dying out on the freeway
  3. May 5, 2012 at 10:54 PM
    TACOsupremacy
    Gaven
    Aiea_Hawaii
    05taco
    Never satisfied
    Nope didnt do any of the above..i did gap it properly, i didnt put alot of antiseize..infact i followed the write up on here. The plugs i bought are oem nothing different jus replacements. As far as i know a friend jus told me it happened to him, just a ignition coil wasnt seated properly..i checked all my hoses and its all good so i guess ill just redo it tomorrow :(
  4. May 5, 2012 at 11:01 PM
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    yeah make sure the coil packs are g.
  5. May 5, 2012 at 11:08 PM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    I would definitely recheck the coil packs. I may seem that everything is clicked in, but double check
  6. May 6, 2012 at 12:02 PM
    TACOsupremacy
    Gaven
    Aiea_Hawaii
    05taco
    Never satisfied
    Redoing everything at the moment and noticed that the plugs were kinda lose..didnt even have to put that much muscle into losening it..im hoping it couldve been that?? That it was maybe to lose??
  7. May 6, 2012 at 12:06 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Loose plugs could be the issue.
  8. May 6, 2012 at 12:09 PM
    TACOsupremacy
    Gaven
    Aiea_Hawaii
    05taco
    Never satisfied
    Thanks guys..appreciate it. Ill post up after i drive it around
  9. May 6, 2012 at 12:48 PM
    TACOsupremacy
    Gaven
    Aiea_Hawaii
    05taco
    Never satisfied
    Drove it around the block couple times and tjis time was the worst..i was at a traffic light then my idle jus completely dropped. Truck died out, i could start it again but when i push on the gas it seemed like it was bogging out. Idk what this is already. Lol im scared to drive my truck..
  10. May 6, 2012 at 1:22 PM
    Bishop2Queens6
    SoCal
    2009 DCSB SR5 4x4
    Maybe your alternator is going out?
  11. May 6, 2012 at 2:09 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Somthing is disconnected. Check all the connections, MAF, VSV, vacuum line at the rear side of the intake (next to the fire wall), etc. You might also have a cracked plug. At this point, you should re do the change, taking note to plug things in correctly, and check the plugs for breakage. You should have gotten a CEL (Check Engine Light) with that type of failure.
  12. May 6, 2012 at 2:23 PM
    boshak
    boshak Well-Known Member
    AG
    CA
    2003 Manual 4x4 5VZ-FE
    You used a spark plug socket with rubber insert, right? Did you torque them down to spec?
    Do you have a multimeter? Inspect the coilpacks/wires... Not just visually but with the tool.
    x2 on finding something disconnected. Go back and ensure 100% that you didn't miss anything.
  13. May 6, 2012 at 2:36 PM
    TACOsupremacy
    Gaven
    Aiea_Hawaii
    05taco
    Never satisfied
    No lights are on, torqued it 15 lbs, i guess ill double check all my connections..i did gap it to spec on chris 4x4 write up..i pretty much jus follwed it. As far as a cracked plug tho?? Ill check for that and redo everything again..3rd times a charm
  14. May 6, 2012 at 10:16 PM
    TACOsupremacy
    Gaven
    Aiea_Hawaii
    05taco
    Never satisfied
    Alright i give up...i re did everything and bought new plugs gapped it and everything you suppose to do..same thing dying out or bogging out..its going to a shop tomorrow
  15. May 6, 2012 at 10:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Thats really bizare. Lets us know what they say. Sounds like it could be the MAF or 10 amp ECU fuse, if nothing else......
  16. May 6, 2012 at 10:24 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    Did u disconnect the battery at all??
    I know my truck drops rpms and has died on me at a light because the ecu goes into like a reset/check mode after a while of not having the battery connected...
  17. May 6, 2012 at 10:41 PM
    TACOsupremacy
    Gaven
    Aiea_Hawaii
    05taco
    Never satisfied
    No i didnt disconnect the battery for anything...maybe i should? Let everything reset??
    Nice truck btw
  18. May 6, 2012 at 10:55 PM
    boshak
    AG
    CA
    Low idle / rpms... Truck dies. When's the last time you cleaned your MAF and Throttle Body?
    Are you sure the plug wires are connected in the right order?
  19. May 6, 2012 at 10:59 PM
    amaes
    amaes Cuz Stock Sucks
    Alex
    Phoenix, AZ
    2011 FJ Built
    ICON Stage 6, RCI Skids, Blacked out
    Vacuum hose off or loose? I know another member's almost dies under High load for periods of time but we think is his URD MAF Calibrator leaning out the truck and throwing the ecu into a safe mode.
  20. May 6, 2012 at 11:03 PM
    spark4
    spark4 Well-Known Member
    So Cal
    2018 Tacoma TRD OR 4x4 Cement
    Bilstein 6100/5160, Ray 10's, 5.29, KDMax Tuned
    When I changed the plugs on my gf's solara it wouldn't keep an idle right after. I had to literally drive with two feet to the dealership. One on the brakes and the other on the gas so I could keep idling at a red light. Made it to the dealership and the service guy asked me if I just changed my plugs. Which I did. He said to disconnect battery for a bit and then keep driving around. Something about the car computer needing to re adjust itself. It worked. Needed to drive around for a couple miles after and it's all good now. Just my thoughts
