Spark plug problems
Discussion in 'Technical Chat' started by The tacoman, Nov 18, 2009.
  1. Nov 18, 2009 at 1:41 PM
    The tacoman
    The tacoman [OP] Well-Known Member
    Texas
    2006 TRD
    I changed out my spark plugs the other day and they were gapped correctly and tightened down and everything seems to be correctly hooked up and back in place, but my gas mileage since changing them has dropped almost 5 mpg. Any suggestions what this could be? I didn't know if it was possible to just have a bad spark plug, and if so what i could do to figure out which one. Any help is greatly appreciated.
  2. Nov 18, 2009 at 1:43 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Something isnt right....How many miles? Engine type? Mods?
  3. Nov 18, 2009 at 1:53 PM
    The tacoman
    Texas
    2006 TRD
    I used the OEM denso plugs. Bought them at the dealership. My truck is an 06 double cab trd. I had gotten about 17-18 mpg, but only ran a half a tank through it this time and noticed that the fuel gauge was going quicker than normal, filled up and got just over 12 mpg. Don't have any mods that should affect it. I guess I may just take them all out again and double check everything.
  4. Nov 11, 2011 at 9:12 AM
    oregonianincalifornia
    oregonianincalifornia Member
    Orange County
    09 TRD Off Road 4x4 STICK (black)
    Tacoman,
    Did taking it apart and fixing it help? I have the exact problem. After searching the threads this is the only one I could find.
    Thanks
  5. Nov 11, 2011 at 9:14 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I had the same problem , but it only occurred for the first tank if gas after the plug change , then went back to normal .
  6. Nov 11, 2011 at 9:18 AM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    2009 thread revival...
  7. Nov 11, 2011 at 9:19 AM
    Orange County
    great, thanks. Hopefully after the next tank it will return to normal. I will update if it does.
    Revived threads sometimes help!
  8. Nov 11, 2011 at 9:20 AM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    My bad, I misread yours about having the same issue :thumbsup:
  9. Nov 11, 2011 at 9:23 AM
    OZ-T
    Peter North
    British Columbia
    Gestapo
  10. Nov 11, 2011 at 9:27 AM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Thats policia to you
