Spark plug PSA
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoSupremo19, May 16, 2022.
  1. May 16, 2022 at 7:58 PM
    saint277
    saint277 Vigilo Confido
    Whos offended? I'm just wondering if they were loose from the factory or loosening overtime.
  2. May 16, 2022 at 8:11 PM
    TacoSupremo19
    TacoSupremo19 [OP] Well-Known Member
    NJ
    2019 Black Tacoma TRD SPort DCSB
    Brushed Copper Blaze 10 Rims | 265 70 17 Toyo Open Country A/T III tires | Bilstein 5100 w/ Eibach Coils 2.5" lift | Blackhawk UCAs | ICON Rear 3 AAL |TRD Skid Plate | TRD CAI | OEM Rear Bed Lighting | OEM rear Tailgate lock | RC Bed Molle Racks | Custom Blacked out OEM LED Headlights | MESO V4 Mirror Turnsignals | MESO Interior trim blackout | TG DMM dash mount | TRD Shift Knob | OEM SR5 interior door handles | Upgraded Stereo including Alpine 700W Amp Alpine Type R Components & Hertz speakers 12" Sub | Custom Clazzio Seat covers | Mobtown Sliders | Front Camera
    I'm sorry. Did I say you or I was offended? I said you might be right. I do apologize if I came off different then how I wanted to. That's the problem with text. I honestly don't know the answer to your question. I am only reporting the issue I encountered to help others. I'm not the first to bring this up though.
    Superdave1.0 and JJ Diablo like this.
  3. May 16, 2022 at 8:24 PM
    TacoSupremo19
    NJ
    Looking at the pics
    What do you think? I think they all look the same. Are they crushed appropriately I don't know. I guess I could take and easy one out on the passenger side to compare. That's really the only way to answer your question.
  4. May 16, 2022 at 9:37 PM
    CPS-65
    CPS-65 I’m good for some, but I’m not for everyone.
    Alta Loma, CA
    2019 Quicksand TRD Off Road 4X4
    Mostly old man mods
    “Screws fall out all the time, the world is an imperfect place”. - John Bender
    Now I’m checking mine this weekend. Maybe the spark plug monkey was off his game that day.
    KittySlayer, Big tall dave and Anslet like this.
  5. May 16, 2022 at 9:43 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    It happens
    You found it
    Sounds like these latest ones are snug, I wouldn't worry about it
    Junkhead likes this.
  6. May 17, 2022 at 12:08 AM
    Jadamjr
    Jadamjr Well-Known Member
    Jonathon
    Phoenix,AZ
    2017 DCLB TRD OR
    Thanks for the heads up! I’ve been kind of going over everything preventative wise, I’ll be sure to check on mine.
    PokerPilot likes this.
  7. May 17, 2022 at 5:14 AM
    willtill
    willtill Well-Known Member
    Maryland
    2018 Cement Off Road V6 Access cab
    I have still have a rough idle when fully warmed up. I need to check the rest of my plugs, been in the shop three times now for three coils replaced, a Plenum replacement and also a loose plug.
    What is the torque on the plugs? 13ft lbs? I want to pop the hood today and just check all of them myself.
  8. May 17, 2022 at 5:20 AM
    TacoSupremo19
    NJ
    13 ft/lbs
    willtill[QUOTED] likes this.
  9. May 17, 2022 at 5:58 AM
    vols_and_tacos
    vols_and_tacos Member
    Johnson City, TN
    2021 SR V6 4WD in MGM
    KMC 542 Impact Wheels That cliché grill swap
    Hey OP, what were the original symptoms that led you to check the plugs? Just a miss at cruising? I've always had a surge/shudder around 50-55 mph that's intermittent. Not constant enough to call a vibration. Significantly worse on hotter days, A/C on full blast, or the truck is warmed up. But it never misfires bad enough to throw a code. And I only have 20k miles on the clock.
    Edit: Yes I know you gave a quick highlight reel to start the thread but I was hoping you could elaborate on the problems! Thanks
  10. May 17, 2022 at 6:47 AM
    TacoSupremo19
    NJ
    Ever since I had the truck it wasn't very smooth while cruising. I had a slight sputter while cruising most noticeable at RPMs lower than 2000 RPMs. No codes ever thrown. Seemed to run fine when accelerating and towing. I've always had the surge, as you described, when accelerating from 15 to 35 MPH. I believe that's the crappy transmission shift points. The tunes I applied minimized to practically eliminated that. I have the Nexus tune which I highly recommend.
    I just think it might be in people's better interest to pull the coils on the passenger side just to do an initial check. Takes about 10 minutes.
  11. May 17, 2022 at 3:06 PM
    WinterFalco
    WinterFalco Well-Known Member
    Donald
    2018 Midnight Black SR 4x4 Double Cab
    Added aftermarket Rims and Tires, Fog Lights, Mudflaps, Entune with Nav
    They are only designed to torque once. If you take them out to check them. They will not seal again (as the washers are now crushed).
  12. May 17, 2022 at 3:26 PM
    TacoSupremo19
    NJ
    jerkwithkeyboard likes this.
  13. May 17, 2022 at 5:45 PM
    mckgyver
    mckgyver Well-Known Member
    2020 TRD OR silver
    @vols_and_tacos Mine does the same thing. 23k miles. i just check my plugs today and they were all tight, replaced them anyway since i was in there. still have the misfire issue. Mine is tuned also. Drives me nuts.
  14. May 17, 2022 at 6:17 PM
    Notoneiota
    Notoneiota Well-Known Member
    Oakdale, MN
    14 Tacoma DCLB TRD Sport
    Mostly stock with a few minor mods.
    I see 6 Denso plugs. Doesn't Toyota still use 3 Denso and 3 NGK like they did on the 2nd gens? If they still do, that means someone changed the plugs after the factory did.
  15. May 17, 2022 at 6:18 PM
    #35
    mckgyver
    2020 TRD OR silver
    they are all Denso plugs in the 3rd gen. Just had mine out today
  16. May 21, 2022 at 2:09 AM
    #36
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Did mine yesterday. I have 20K miles and pulled a few out. They looked still fairly new but I replaced them. Never had an issue before, I run 93 octane, KDMAX Pro tune and plugs looked great. Anyhow I used new OEM plugs, drives and feels no different than before. Mine runs and drives perfect but I wanted to be sure. I have a JLT catch can I have been running for a few years so maybe a catch can helps!
  17. May 21, 2022 at 4:37 AM
    #37
    TacoSupremo19
    NJ
    Wow 20K and no issues and you still changed the plugs? As long as you have piece of mind now, it's all good.
    Really I only wanted people who think they might have an issue I had to take out their coilpacks and look for staining. If all is good and plugs aren't due for changing then put it back together and keep on rollin'!
    shotgunbilly420 likes this.
  18. May 21, 2022 at 8:22 AM
    #38
    Chaosh1
    Chaosh1 Well-Known Member
    2021 Tacoma TRD Pro
    I might grab a beer and go check mine... Ill just inspect the coil pack and retorque the plugs.. not really into pulling the plugs
  19. May 21, 2022 at 8:48 AM
    #39
    TacoSupremo19
    NJ
    If the coils are clean no need to remove the plugs
    I only replaced mine because I was wasn’t too far from 60k
  20. May 21, 2022 at 9:13 AM
    #40
    Chaosh1
    2021 Tacoma TRD Pro
    yea, I have 5500miles on the truck.. Figure it gets me out of the house, puts a beer in hand and just double checks
