Spark Plug Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SportyHeretic, Jan 13, 2013.
  1. Jan 13, 2013 at 8:58 PM
    SportyHeretic
    SportyHeretic [OP] Well-Known Member
    Jeremy
    Wyoming/South Carolina
    2010 Sport
    Icon Stage 3 Suspension, Diff Drop, MagnaFlow Cat-Back Exhaust, Tonneau Cover
    Im coming up on 30k miles, and will be replacing my spark plugs. V6 automatic. Just wanted to see if Toyotas plugs are they way to go or is there another brand that is superior. thanks for the help.
  2. Jan 13, 2013 at 9:02 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Use Factory specified unless you are supercharged.
    Denso SK20R11 or NGK ILFR6C11. Both can be purchased from online or in common auto parts store so as to avoid dealer markup.
    Gap at .043"
  3. Jan 13, 2013 at 9:05 PM
    SportyHeretic
    Jeremy
    2010 Sport
  4. Jan 14, 2013 at 5:29 AM
    miniceptor86
    miniceptor86 Well-Known Member
    Jim
    McGregor,IA
    07 Speedway Blue Prerunner Dbl cab
    TRD sport exhaust and cold air intake, nerf and bull bar, RideRide, ProEFX towing mirrors, BakFlip F1 trifold tonneau
    Denso iridiums. But once you see them you might not want to hide them. They just oose quality, almost like motor jewelry.
    Jim
  5. Jan 14, 2013 at 5:44 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    If you like spending 3-4 times the money for 0 gain, then yes, get the iridiums for your V6... :rolleyes:
  6. Jan 14, 2013 at 6:39 AM
    miniceptor86
    Jim
    McGregor,IA
    YA YA, its just a feel good thing! Like adding a lot of other things to your ride, CAI, TRD Sort exhaust? Probably not a big gain either but I like the sound when I get on it. Leather heated seats for me? Would be nice but a margin gain for me. Big tires, lift, new wheels, 4wd, YA YA margin gain as stock Prerunner works fine for me. Diamond ring for the wife? Margin gain for me except for the feel good feeling.
    Just lavishing a little affordable love on BluTaco.
    Jim
  7. Jan 14, 2013 at 8:07 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    IMHO
    regular copper Denso from Toyota are the best choice for V6 (non-supercharged)
    They clean well, they work, and they are not expensive.
  8. Jan 14, 2013 at 9:05 AM
    SportyHeretic
    Jeremy
    2010 Sport
    Haha, thanks. I do like to treat my baby with lavish gifts to keep her happy.
    Thanks for the info guys
  9. Jan 14, 2013 at 9:16 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    This. In some cases, platinum plugs have given issues. OEM denso plugs are the best.
  10. Jan 14, 2013 at 9:19 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Most people who install iridium plugs get worse mileage from what I have read.
    That said I have 4 brand new ones in the box....who wants them dirt cheap.
  11. Jan 14, 2013 at 9:20 AM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Just picked some up from camelback Toyota and were like 2.56 a piece....thought that was a decent price.
    Shouldn't they be gapped around .040 ish? Does it matter?
  12. Jan 14, 2013 at 9:21 AM
    XXXX
    sKiP
    05 Prius
    see post #2...
    god yes it matters.
    look up how a plug works.
  13. Jan 14, 2013 at 9:23 AM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    Ya, I meant is there much difference since my manual says .039-.043 ?
  14. Jan 14, 2013 at 9:28 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Gap them at .040 to .041
  15. Jan 14, 2013 at 9:28 AM
    Pugga
    Massachusetts
    Not to knock Camelback but I ordered plugs from them also, check the part nos. I got 5 of the correct part no. and one that was iridium. They fixed the problem and sent me the right part but just check your part nos. Also, 4 out of 5 that I did get were gapped correctly, I had to fix the 5th. So yes, it's important to gap your plugs, even if they claim to be 'pre-gapped'.
  16. Jan 14, 2013 at 9:30 AM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    Thanks boss!
    Right.....I checked before I left!
  17. Jan 14, 2013 at 9:31 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Interested... sent PM
  18. Jan 14, 2013 at 5:59 PM
    dwr80
    dwr80 Well-Known Member
    thanks for the thread... I have 73K on a 09 trd sport, dc short bed and was thinking of replacing the original plugs. When you buy the plugs they come with the correct gap?
    Are most of you speaking of bosch plugs as your replacements?
  19. Jan 15, 2013 at 5:56 AM
    miniceptor86
    Jim
    McGregor,IA
    Hi,
    No they don't always have with the correct gap. Always check the plug manufacturer's specification.
    No Bosch plugs for me! NGK or Denso. I had combustion gas blow by between the insulators and metal body with new Bosch plugs on my '97 Contour V6 and changing the back ones is not fun!
    Jim
  20. Jan 15, 2013 at 9:04 AM
    AlanLoshbaugh
    AlanLoshbaugh Well-Known Member
    Alan
    Columbia, MO
    2013 Tacoma Double Cab 4x4
