Spark Plug Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dlee58, Mar 19, 2016.
  1. Mar 19, 2016 at 7:49 AM
    dlee58
    dlee58 [OP] New Member
    I took my 2015 Tacoma in yesterday for the 25,000 service, my last free service at the dealership. As I am leaving the tech tells me that the next service at 30,000 spark plug replacement is recommended. He says Toyota still uses nickel plugs and they need to be replaced every 30,000 along with an injection cleaning. Roughly $199 for the plugs and 149 for the injection cleaning.
    I thought I would come to the people who know and see if this sounds correct or get other recommendations.
    I don't post a lot but I do read quite a bit here and you guys are most helpful.
    Thanks
    David
  2. Mar 19, 2016 at 8:03 AM
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    Chevron techron injector cleaner at any auto store for under 10 bucks is all I've used for the injectors. The plugs aren't that bad to change. You could do the whole job for probably $30 bucks, or buy the plugs and have a buddy or independent shop put them in. This dealer is pumping up the price.
  3. Mar 19, 2016 at 8:18 AM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    Better deal than I was quoted - $300.00 for spark plugs alone.
  4. Mar 19, 2016 at 8:24 AM
    Shelf Life
    Rob
    Central Oregon
    That's insane.
    shakerhood likes this.
  5. Mar 19, 2016 at 8:24 AM
    nh_yota
    nh_yota Well-Known Member
    Jeff
    Portsmouth, NH
    2010 DC V6 TRD-OR 6-SPD
    2" Lift with HS coils/AAL and 5100s, TRD Exhaust, TRD Skid Plate, URD Short Shift, AT3s
    The injector cleaning is an upsell for them and you don't need it. Modern gasoline has enough cleaners in it already and if you drive your truck on a regular basis all you should ever need to do is throw a bottle of Techron or Seafoam in the gas tank every 10k miles or so, if that.
    Kyitty and Shelf Life like this.
  6. Mar 19, 2016 at 8:35 AM
    McTeague
    McTeague Well-Known Member
    Alan
    2012 MGM Tacoma DCSB TRD Off Road
    Stock
    Injectors do not need cleaning it is not the 70s.
    Change your own plugs its not that hard if you plan ahead and research it.
    Plugs are $2 each but you need to research what the 30k maint actually requires, its more than plugs and does not include injector cleaning. RTFM
  7. Mar 19, 2016 at 8:56 AM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    You don't say what engine you have. Even the 6cyl. is not that hard. And I thought 60k was the new recommendation. And I would use whatever was in there stock (NGK or Denso in my case).
    That price looks inflated. But I think $130/hr is insane (my dealer). They're probably charging you 1hr min. + parts (with dealer markup) + shop fee and whatever else they can think of.
  8. Mar 19, 2016 at 9:11 AM
    gmann1972
    gmann1972 Well-Known Member
    Greg
    Rhode Island
    2013 tacoma SR5 DCSB
    Dealer mark ups are insane anywhere and everywhere, no matter the industry, auto, heavy equipment, RV, Boat ect....Example, I work for a well known Heavy Equipment Dealer, in Mass, I am a Field Service Technician and I'm on the road everyday...My dealer chargers, $165.00 per hour, and $2.00 a mile, minimum service call is 4 hrs, that does not include any parts used to repair the equipment, that's just time and labor, miles. So do the math, dealerships are making a killing...Sad that's what the world is coming to...it's all business...
  9. Mar 19, 2016 at 9:14 AM
    Mad Man Marty
    Mad Man Marty Well-Known Member
    Marty
    PA
    2007 Tacoma SR5 TRD Sport
    6speed, TRD intake, bed tie downs, weathertech rear,Tint
    Do it yourself.
    Go to maintenance threads here on TW for more info.
    robssol likes this.
  10. Mar 19, 2016 at 9:31 AM
    devkurf
    devkurf Member at Large
    midwest
    Holy cow! You could buy the plugs, any tools you will need, and buy a registered Labrador Retriever to watch you do the work at that price.
    bm00re, CroResident, Markcal and 4 others like this.
  11. Mar 19, 2016 at 9:58 AM
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
    Lol.....yea that tech/dealership is going to give you an "injection cleaning" alright and along with their so called "nickel plugs" (what bullshit!).
    Bascially what they are telling you is to "bend-over" because they're going to give you an injection cleaning then plug you alright!
    Don't fall for that crap!
    Buy the spark plugs and install them yourself and as far as this so called injection cleaning, well I never have had to do that. My 08 runs great ever since I bought it brand new and drove it off the lot, have changed the spark plugs once a year (reguardless what the manual or anyone else says/recommends) and haven't had any problems-ever!
    Bottom line is the choice is yours and yours alone.
    Beaglesridefree likes this.
  12. Mar 19, 2016 at 10:09 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    heres some general information at the link below...this says 60,000 depending on driving..also depends if your fuel mileage is going down....typical newer vehicles should last to 100K...@30K I bet they wont even change them and then charge you for it...I did a tune up on my Nissan and it was over 100K and the plugs didnt look bad...but I changed them anyway...I noticed no fuel mileage decrease...I call BS on their 30K...if so they have inferior products...
    http://partsblog.olathetoyota.com/4456/tacoma-maintenance-spark-plugs/
  13. Mar 19, 2016 at 10:11 AM
    Shelf Life
    Rob
    Central Oregon
    Any good independent shop can do warranty or maintenance work if you aren't a do it your selfer. It doesn't have to be done at the dealer. I just had my auto trans serviced at my respected shop for half the price the dealer in town wanted.
  14. Mar 19, 2016 at 10:13 AM
    wilcam47
    Will
    Bourbon state
    Thats true too....plus if you schedule it they can usually have you in and out of there a lot quicker than at the dealership....
  15. Mar 19, 2016 at 10:16 AM
    Shelf Life
    Rob
    Central Oregon
    Yep. They had it in and out in an hour and a half, and it shifts great.
  16. Mar 19, 2016 at 10:32 AM
    Kevinztaco
    Kevinztaco Well-Known Member
    none yet
    Not you OP but it is mind bugling to see how the stealerships take advantages on women and the elderly drivers.
  17. Mar 19, 2016 at 11:10 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Toyota uses copper plugs in the 1GR-FE Engine and they should be changed every 30K Miles as per the schedule.
    $199.00 for the plug replacement is retarded. As stated earlier you could purchase the tools and do it for less than 199. Way less. There is lots of how to's and assistance here if you need it.
    As for the fuel injectors.... A complete rip off. I work in the fuel injector manufacturing business, Robert Bosch LLC. You should never have to do anything to the fuel injectors other than run a good quality gasoline and if it makes you feel better a bottle of Techron or Seafoam in the Gas Tank every 5 - 10 k miles. Crud doesn't get into the injectors as they are closed at the gas entry tube with a 1 micron filter. They are welded together and can not be disassembled for cleaning.
    $149.00 for a bottle of crap squirted through the injectors is a waste of money. Do it yourself for less than 5$.
    Markcal, kurtw and Kyitty like this.
  18. Mar 19, 2016 at 1:53 PM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    +1 Just did mine last weekend for around $25 took me about two hours, just taking my time making sure I was doing it correctly.
    Explor likes this.
  19. Mar 19, 2016 at 2:49 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    The 30K involves a lot more than just plugs, change of all gear oil, all filters plugs on the V6 etc. read your manual. There is nothing about "injector cleaning" but I suppose you could take them out and run them through the dishwasher. The plug change is all about emissions on the V6 and emission parts warranty.
  20. Mar 19, 2016 at 3:06 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Really?
    Lester Lugnut and Kyitty like this.
