Spark Plug Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dlee58, Mar 19, 2016.
  1. Mar 19, 2016 at 5:03 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Have to use Jet-Dri to guarantee the tips are clog free.
  2. Mar 19, 2016 at 8:30 PM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    Has Gunk come out with an injector cleaner that you can use in a dishwasher yet?
  3. Mar 20, 2016 at 5:40 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    No but it's equally as ridicules as pouring a bottle of crap in the tank for $150. I have never used "injector cleaner" in any thing I owned or any other additive for that matter when I buy them I drive them till they are worn out or 300K what ever comes first.
  4. Mar 20, 2016 at 6:44 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    The tech forgot to mention that you will also need a power steering fluid flush and brake cleaning. Those 2 items are usually included in the "upsell".
  5. Mar 20, 2016 at 7:13 AM
    gmann1972
    gmann1972 Well-Known Member
    Greg
    Rhode Island
    2013 tacoma SR5 DCSB
    You will also need to flush the old air out of your tires and put new fresh air in....
    bm00re and Blackouts like this.
  6. Mar 20, 2016 at 7:14 AM
    1Shifter
    1Shifter Well-Known Member
    Jeff
    Outta the black and into the blue
    09 PreRunner
    Same as everybody else...
    My local dealer quoted me 296.00 to change the plugs. I'm going to buy the plugs and a nice ratchet extension and try it myself. I'm not the most mechanically inclined person but I've done work on the truck thanks to TW so I'm gonna give it a shot.
  7. Mar 20, 2016 at 7:17 AM
    hotrod53
    hotrod53 Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    +1 in Techron and change them yourself in about 20 minutes. Go to the dealer and buy 6 Denso plugs, don't forget to put some anti seize on the threads, and don't be shocked when you pull the originals and find that you have NGK on one side and Denso on the other. That's how they are built. You'll need at least a 6" extension to get to the plugs, they're down in there a ways.
  8. Mar 20, 2016 at 7:47 AM
    Ztextreme
    Ztextreme Well-Known Member
    Scott AFB
    2010 Tacoma DDl Sport
    Icon stage 1, wheelers aal, icons uca, wheelers superbumps, allpro flip kit, bora .75 spacers, mastercraft 265/70/17 mxt, frontrunner roof rack, relentless skids, bamf lca skids, Avid bumper guard,
    Last weekend i did my spark plugs for the 2nd time, took about 30 minutes and 25 bucks worth of denso plugs, gapped all to .042 with no antisieze to 15ftlbs with torque wrench. I also flushed my power steering fluid, took 30 minutes and 1 quart of mobile 1 syn atf. Its easy stuff with a basic skill level that the dealers charge way to much for, just my 2 cents
  9. Mar 20, 2016 at 7:53 AM
    edm3rd
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    Although plugs from the dealership are supposedly pre-gapped, check to confirm. A spark gap tool is only $1-3. Minimum is .041 inch.
    Also, di-electric grease is suggested on the plug where the coil connects.
  10. Mar 20, 2016 at 8:05 AM
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    You like the Denso's? I put in NGK's last time, but I was going to try all Denso's next time.
  11. Mar 20, 2016 at 8:05 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Always check and gap copper plugs.
    Always check Iridium plugs, if they are off too much take them back to the store.
    Do Not attempt to gap them as the Iridium is very brittle and could chip.
  12. Mar 20, 2016 at 10:36 AM
    McTeague
    McTeague Well-Known Member
    Alan
    2012 MGM Tacoma DCSB TRD Off Road
    Stock
    I prefer NGK myself...
  13. Mar 20, 2016 at 12:43 PM
    TACK
    TACK Well-Known Member
    Nevada
    10 PreRunner TRD Off-Road MGM
    Bilstein 5100s at 1.75", Level 8 Tracker wheels, white lithium grease mod for creaky clutch pedal
  14. Mar 20, 2016 at 3:32 PM
    hotrod53
    Lynd
    Pittsburgh, PA
    I've had no issue with the Densos. Purchased for no special reason other than they were available and reasonable. I don't think the designer plugs are anything more than snake oil or an overpriced alternative that won't payback its cost. I ran NGK in all of my 2 stroke engines and always thought highly of them. Indont think you could go wrong with either.
    As mentioned, always check your gap. A dropped box or plug would easily get knocked out of spec.
  15. Mar 21, 2016 at 6:45 AM
    #35
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Be sure they use only genuine Toyota "Pure Nitrogen" type 3 only.
    Ahougland89 and tan-ishman like this.
  16. Mar 21, 2016 at 6:53 AM
    #36
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    If you do a proper 30K service it is not going to be cheap. When I did mine I changed all the gear out for syn. oil, plugs, all the filters new engine oil every thing on the list it cost me over $200 with my shop discount for all the parts.
    McTeague likes this.
  17. Mar 21, 2016 at 7:30 AM
    #37
    McTeague
    Alan
    Stock
    Same here
  18. Mar 21, 2016 at 8:16 AM
    #38
    Ahougland89
    Ahougland89 Well-Known Member
    Anthony
    Orting, Washington
    2007 Tacoma 4x4 6spd Manual
    3inch lift 33inch TOYO M/T
  19. Mar 21, 2016 at 9:19 AM
    #39
    MKMotorsport
    MKMotorsport Well-Known Member
    AZ
    '15 DCSB TRD/OR
    All-Pro skid'd, UGMx1.3, 7pin delete via rock
    Buy some good NGK plugs $3-4 a plug.
    Buy a bottle of Techron (I use this as it is effective and cheap), or the BG stuff if you are rich..
    Buy the tools you need to do it...
    Call it a day.
    Back in the day GM's doorstopper shaped Camaro's 99-00 ish required 4 hours of dealer labor to change the plugs. $300 is about right for one of those. Any other vehicle, that is a pure and simple rip-off.
  20. Mar 21, 2016 at 11:35 AM
    #40
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    You forgot the most important thing.... a few cold ones.
