Spark plug recommendations for 2TR-FE??
Discussion in '4 Cylinder' started by Gundam_Kyoto20, Jun 25, 2024.
  1. Jun 25, 2024 at 1:14 AM
    Gundam_Kyoto20
    Gundam_Kyoto20 [OP] Well-Known Member
    2012 White Tacoma SR5 Prerunner
    Steering wheel cover
    Gonna be changing out the spark plugs of my 2012 Tacoma 2.7, while I’m doing my oil change and replacing my brake pads. Don’t exactly remember what spark plugs were installed before, (it’s been a while) I heard to go with iridium plugs but what brand will be best??.
  2. Jun 25, 2024 at 1:35 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  3. Jun 25, 2024 at 2:20 AM
    rustyfromskowhegan
    rustyfromskowhegan Well-Known Member
    2013 AC 4x4
    Agree. Go with OEM. The 2.7 only needs them every 100k I believe. Just get the OE denso’s and call it a day
  4. Jun 25, 2024 at 2:28 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    NGK or Denso. NGK says antiseize is not needed on their plugs but I had a seized NGK plug I struggled with on a Corolla once. So, I now put that shit on everything. Do remember to reduce the torque by about 15%.
  5. Jun 25, 2024 at 9:40 AM
    Gundam_Kyoto20
    I’ll remember about the antisieze, I heard Denso is a good choice. The others say oem but like I mentioned, I don’t know what spark plugs are in this truck. I got it used. Do you happen to know how much torque I should put when putting in the spark plugs?
  6. Jun 25, 2024 at 11:02 AM
    rustyfromskowhegan
    2013 AC 4x4
    OEM plugs are Denso’s. For the torque spec I think there’s a sticky in the 4cyl forum on replacing the spark plugs that should have the torque. If not, search the forum. It’s definitely on here somewhere
    Gundam_Kyoto20[OP] likes this.
  7. Jun 25, 2024 at 11:40 AM
    Chuy
    Lakeside, CA
    Silver Taco
    It is 13 ft-lbs. 11 with antiseize. Toyota/Lexus uses both NGK and Densos as oem plugs across their models. My V6 had both! 3 Densos on one bank, NGK on the other.
  8. Jun 25, 2024 at 12:04 PM
    Robnik
    Robnik Disciplined Maniac
    Rob
    Greenacres, Florida
    2012 Base Reg Cab 2.7L 2TR-FE A340E
  9. Jun 30, 2024 at 1:52 PM
    demur
    demur Member
    S NJ
    2020 SR 4X4
    These are what I used
    Denso 3509 FK20HR-A8 Iridium Long Life Spark Plug
    SKU: FK20HR-A8
    got them from sparkplugs.com as that was one of the listed online retailers on denso's website. Trying to avoid any fakes
