Spark plug removal interference
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bernard, Apr 28, 2012.
  1. Apr 28, 2012 at 10:31 AM
    Bernard
    Bernard [OP] Member
    Bernard
    SoCal
    2003 Tacoma
    Hiya!
    2003 Tacoma 2.4L. How the heck do I remove the air intake tube, in order to change the spark plugs?
    I've already changed the 1st & 4th plugs, which were easy to reach.
    Arrrgggh!
    Thanks in advance! :)
  2. Apr 28, 2012 at 10:39 AM
    boshak
    boshak Well-Known Member
    Tony
    Southern California
    2003 Manual 4x4 5VZ-FE
    OME 881's, Wheeler's 5-leaf pack, Bilstein 5100's
    Unscrew the clamps connecting the tube to the airbox and the throttle body.
    You might need to twist the tube a bit to get it loose.
  3. Apr 28, 2012 at 10:44 AM
    Bernard
    Bernard [OP] Member
    Bernard
    SoCal
    2003 Tacoma
    Cool! :) I'll try it. I was afraid I was going to have to remove everything back to the air cleaner.
  4. Apr 28, 2012 at 10:48 AM
    medic2230
    medic2230 Ditch Doctor
    Murph
    Bama! Roll Tide
    2011 Taco 4x4 DCLB
    20% Tint, OME 3"complete lift with Dakar's, Light Racing UCA's, 285/75/16 Nitto Terra Grapplers, 10 HP TW sticker, Ultraguage, B.A.M.F. Rock Sliders, MedicFab Bed Rack, Relentless front bumper
    You may need to take the box there to the left in the pic off too to get it out of the way. There's 2 nuts underneath it either 10 or 12 mm if I recall correctly and all of that will pull out of the way.
  5. Apr 28, 2012 at 11:01 AM
    Bernard
    Bernard [OP] Member
    Bernard
    SoCal
    2003 Tacoma
    Found 'em. Two 12mm bolts.
    Thanks, guys! :)
  6. Apr 28, 2012 at 1:05 PM
    Bernard
    Bernard [OP] Member
    Bernard
    SoCal
    2003 Tacoma
    Update:
    You were absolutely right about those two nuts underneath the box. It turns out that the last person who removed the box didn't bother screwing the nuts back on, and it was just mushed into place.
    I removed the two sideways 12mm bolts, which bolt the steel support platform for the box to the engine block, by mistake instead.
    It worked, but it's lots easier to just be aware of the two nuts under the box.
    Oh well...it's all done. I'll know better next time.
    Thanks again, guys! :)
  7. May 9, 2015 at 11:50 AM
    bobastol
    bobastol Member
    OK I know this is an old post but maybe someone might pick up on it. Your
    saying that its absolutely necessary to take the throttle body tube off. No
    way will they come out with it still on? It looks like there is a little clearance to squeeze them
    out. I pulled the first plug and it looked pretty good so I put it back, now I have an extra
    set of plugs. If I just have to pull the plugs it's real easy, if the tube has to come out it's
    a real pain in the ass. I know I could just try it but I thought I might ask first.
  8. May 9, 2015 at 2:20 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    2000 Work truck
    Super Springs
    Wow I must be missing something I never thought pulling the air intake tube was that big of a deal.
    Unhook the wiring attached loosen the 2 clamps done.
  9. May 9, 2015 at 5:27 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    I have an aftermarket intake tube so that might change things but I don't have to remove anything to change the plugs...
  10. May 9, 2015 at 10:00 PM
    bobastol
    bobastol Member
    Mine connects to the throttle body which connects to a air box ( not sure what that's calls) that's
    bolted to the engine with 2 or 3 bolts underneath then connects to the air box where (which gets jammed up by some wiring for an aftermarket alarm someone put in ) the wire harness is.
    If you look on youtube at what some people have done you will see what I'm talking about.
    Why would I go on line and ask this question if all I had to do was unhook some wiring and a couple of clamps?
  11. May 10, 2015 at 1:00 AM
    Wyoming09
    New Tripoli Pa
    2000 Work truck
    Super Springs
    I see different engine I did not see that!!
