Spark Plug Replacement...How often??
Discussion in 'Technical Chat' started by Warren Thompson, Sep 5, 2009.
  1. Sep 5, 2009 at 2:11 PM
    Warren Thompson
    Warren Thompson [OP] GeoTaco
    Warren
    Elko, Nevada
    '06 Tacoma DC TRD Sport RadRed
    The scheduled maintenance manual and TW posts say plugs should be replaced every 30,000 miles. The manual has a numbered footnote stating " replace irridium tips for emmissions puposes" every 30,000 miles. The service manager at my dealership tells me the OEM's should be good up to 80,000 miles.
    WTF??? Anyone have a clear answer here?
  2. Sep 5, 2009 at 2:13 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    30,000 miles.
  3. Sep 16, 2009 at 5:30 PM
    jinxed77
    jinxed77 Well-Known Member
    06 4.0L TRD SR5 4x4
    30,000 on the 06'.If you try to stretch it to 80,000 you will most likely cause damage to the coils.
    I just changed mine on my 06'4.0l tacoma and mine were not platinum plugs. Use NGK or Denso plugs.
  4. Sep 16, 2009 at 5:31 PM
    MY50cal
    MY50cal - IPFK -
    Mojo
    Chester County, PA
    09 PM RC / 05 SWB AC (RIP)
    Yep.
    change mine every 30k. But I change everything before it "needs" it.
  5. Sep 16, 2009 at 5:34 PM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    I don't believe that to be a true statement; damaging the coils. I changed mine @ 80,000 for the first time & have driven 45,000 since. No problems.
  6. Sep 16, 2009 at 6:02 PM
    Warren Thompson
    Warren
    Elko, Nevada
    Thanks guys. I am about 45K miles. I bought my '06 Taco with 40K on it. I am assuming nobody has done any 30K maintenance to it, so I will change the plugs this weekend and replace oil/filter. I will buy OEM plugs (Denso) and OEM filter. For the oil, its Mobil 1.
    GenXer, what did your plugs look like after 80K miles?? Just curious...
  7. Sep 16, 2009 at 6:11 PM
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
  8. Sep 16, 2009 at 6:26 PM
    genxer36
    Sean
    Bethlehem,GA
    They needed replacing. A couple were worn.
    I replaced them with NGK irridiums. Advanced auto sells NGK & maybe Denso. Autozone did not. Easy to do yourself. Took me about 30 minutes. Passenger side was a breeze.
  9. Sep 17, 2009 at 4:51 AM
    jinxed77
    06 4.0L TRD SR5 4x4
    Genxer this is for you, WHY COILS FAIL
    Because worn spark plugs and open-circuit spark plug wires force ignition coils to operate at maximum output, neglected ignition system maintenance is the most common cause of modern ignition coil failure. As the spark plug air gap widens due to normal erosion, increased voltage is required to create a spark in the combustion chamber. This increased voltage, in turn, demands more current flow through the coil’s primary circuit. And, this increased primary current flow can overload the ICM’s primary transistor. The increased secondary current created by the ignition coil also can increase to the point that it perforates the secondary circuit in the coil itself. See Photo 2.
  10. Sep 17, 2009 at 5:25 AM
    Warren Thompson
    Warren
    Elko, Nevada
    This makes sense to me. I will replace mine ASAP.
  11. Sep 17, 2009 at 5:51 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Link for photo and the rest of the info:
    http://www.olyonline.com/new/ICignitioncoil0103.asp
  12. Sep 17, 2009 at 5:52 AM
    -TRDMAN-
    -TRDMAN- ΜΟΛΩΝ ΛΑΒΕ
    Greg
    Clarion Pa
    F-150
    Yikes i need to start thinking bout this i got over 28,000....
  13. Sep 17, 2009 at 2:59 PM
    Yuma Taco
    Yuma Taco Well-Known Member
    Lee
    Yuma, Az
    09 PreRunner DC TRD
    35% tint windows, OEM black running boards, OEM black roof rack, Foglight mod, De-badged & Sockmonkey Horns decals added, Two ammo box storage units (removed), 110 volt & 12 volt outlets for back seat area, EGR Slimline inchannel visors (all windows), Fold-A-Cover G4, Tonneau, Bedmat.
