Spark plug replacement question - 2004 Prerunner 2.7L
Discussion in '1st Gen. Tacomas (1995-2004)' started by Suspender, Dec 5, 2017.
  1. Dec 5, 2017 at 11:03 AM
    Suspender
    Suspender [OP] Well-Known Member
    Colin
    IE, CA
    I recently replaced the spark plugs in my 2004 Prerunner, at 120k per scheduled maintenance guide. First time doing it, I just went with the first option that fit my model which ended up being Bosch iridium (pre-gapped, which I measured at 40). I have this sneaking suspicion that I might have lost a little bit of power, but I may also be paranoid. Am I? (original plugs were NGK)
    Further research showed that a lot of guys like NGK for Asian cars and Bosch for European cars, but idk what the difference is... Thoughts?
  2. Dec 5, 2017 at 11:07 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    I would stick with DENSO or NGK
    cosmicfires and boostedka like this.
  3. Dec 5, 2017 at 1:43 PM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    Iridium, or double iridium? Also, change your wires while your in there.
    Edit, 2.7, no wires, my bad.
  4. Dec 5, 2017 at 1:50 PM
    BillsSR5
    bill
    2014 SR5
  5. Dec 5, 2017 at 4:45 PM
    Suspender
    Colin
    IE, CA
  6. Dec 6, 2017 at 11:58 AM
    BillsSR5
    bill
    2014 SR5
  7. Dec 6, 2017 at 9:57 PM
    Revco
    Revco Got that PMA
    Austin, TX
    '01 Reg Cab 4x4
    stock-ish
    I run NGKs in my 3RZ, every 15k miles I swap them out. Sounds frequent, but I'm OCD about maintenance, plus it's cheap and takes 10 minutes to do after an oil change.
    You won't feel a loss in power over spark plugs. A test across the board of all available plugs/brands/types would likely show a 0-3hp difference, which you'd never feel from the seat. If anything, maybe you didnt fully seat a plug wire, causing a weak spark on a cylinder, but that may bring a CEL.
  8. Dec 7, 2017 at 12:47 AM
    ghs57
    ghs57 Well-Known Member
    Chops
    Catskill Mts. NY
    '17 Grey TRD OR xtracab 3.5L 4WD
    Pretty much stock right now
    I went with Denso last change.
    I'm not sure what wires you would change as the coils (4) sit on each plug on an '04 3RZ.
  9. Dec 7, 2017 at 7:53 AM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    Fixed :thumbsup:
    ghs57[QUOTED] likes this.
