Spark plug socket help
Discussion in '1st Gen. Tacomas (1995-2004)' started by slodoug, Sep 27, 2023.
  1. Sep 27, 2023 at 2:55 PM
    slodoug
    slodoug [OP] Well-Known Member
    changing plugs on my 2002 4cyl, SP socket stuck down there. tips on getting it loose and out?
  2. Sep 27, 2023 at 2:56 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Long needle nose pliers
    Superdave1.0 likes this.
  3. Sep 27, 2023 at 3:11 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Is the socket stuck on the new spark plug? Hate it when that happens. Might have to remove the spark plug and socket together. Then either remove the rubber insert, or slightly hog out the rubber insert.
    Dm93 likes this.
  4. Sep 27, 2023 at 3:27 PM
    rocknbil
    rocknbil Well-Known Member
    Bill
    2003 Taco Ext Cab DLX TRD 4WD MT 3.4L
    I remember having to take a coathanger wire, bend the end of it at 90 degrees or less, slide it in the hole where the extension goes, and with some jiggling and pulling the socket came loose. from there I grabbed it with one of these. When I put it back in I took the standard rubber piece out of the socket and used a short piece of fuel hose so the socket just reached the threads without getting stuck on the plug (enough so it gripped it firmly and wouldn't strip.)
    THatt likes this.
  5. Sep 27, 2023 at 3:53 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    They make spark plug sockets that are permanently attached to an extension for this. They’re nice if you do enough of these.
    Other than that I’d probably do something with a washer inside tbr socket and some string..
    Superdave1.0 and Kwikvette like this.
  6. Sep 27, 2023 at 4:00 PM
    slodoug
    harbor freight and my motorcycle to the rescue... looooooooong nn pliers worked
    Steves104x4, THatt and Bishop84 like this.
  7. Sep 28, 2023 at 5:04 AM
    ctsnow13
    ctsnow13 Well-Known Member
    2014 Magnetic Grey TRD DCSB
    Put your extension in there and take the plug back out. Tape your socket on the extension with some electrical tape and then put the plug back in.
  8. Sep 28, 2023 at 2:57 PM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    Yup this one is the easiest in my opinion. You can wrap some duct tape/electrical tape around the extension and then jam it into the socket to "catch it" in the plug well, then it should come out without falling off
  9. Sep 28, 2023 at 3:01 PM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    First time i did my plugs I read on here to make sure you tape the socket to your extension, and if multiple extensions, tape them together too! I'm glad to have read that!
  10. Sep 28, 2023 at 3:42 PM
    F.I.LetsGoFishing
    F.I.LetsGoFishing Well-Known Member
    95.5 4wd 3rz mt
    Neglected Original
    I just wipe the plastic insert with dielectric grease on a q tip before I start
    slodoug[OP] likes this.
