Spark plug socket.....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Larzzzz, Aug 22, 2010.
  1. Aug 22, 2010 at 6:13 AM
    Larzzzz
    Larzzzz [OP] Grande' Ricardo
    Larry
    MA
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod
    ...won't fit in the bore! To say I was :eek: is an understatement. The engine, 4.0 v6, wasn't cold when I tried to replace them but it wasn't screaming hot either. I had let it sit for about 90 min before I attempted to replace them. The socket would only go in about an inch before it stopped. Anyone else experience this?
  2. Aug 22, 2010 at 6:18 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    Nope...find a thin(er) spark plug socket...cheap at harbor freight. You're not torquing it to much, so don't worry about it not being to beefy.
    Also make sure it's got a decent insert to hold the plug in...you'll love not having to fish the plug out of the well!
  3. Aug 22, 2010 at 6:01 PM
    blackbox
    blackbox Well-Known Member
    SE Ohio
    2010 reg cab 4cyl 5mt 4x4 Pyrite
    ^^, I have seen those sockets in different sizes, I had to buy a smaller one to change plugs on Honda cars I used to work on.
  4. Aug 22, 2010 at 6:03 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    my 5/8ths craftsman socket with a black rubber plug in it...made for spark plugs, works fine for me. changed plugs in a couple of first and 2nd gens with no prob.
  5. Aug 22, 2010 at 6:09 PM
    MxRacer190
    MxRacer190 Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    this lol. I had to use a pair of long needle nose's to get mine out :(
  6. Aug 22, 2010 at 6:27 PM
    TacomaBuzz
    TacomaBuzz Well-Known Member
    CT
    2014 RegCab 4x4 TX Special Edition
    Sirius, Bugflector,back-rack, stepsides.
    I hope you didn't drop any metal shavings into the spark plug opening using needle nose pliers:eek:..... better to have the right tool for the job, a new engine will end up costing you much more!
  7. Aug 22, 2010 at 6:28 PM
    MxRacer190
    Georgia
    06 SR5 4x4 Indigo
    How would metal shavings get into the engine by pulling out the spark plugs?
    am confused :(
  8. Aug 22, 2010 at 6:34 PM
    megillet
    megillet Resident Badass
    Mark
    Atlanta, GA
    2010 4x4 TRD Sport DCSB MGM 6sp
    Mac Tools sells a thin wall spark plug socket, had to buy one to take them off my motorcycle.
  9. Feb 20, 2012 at 2:04 PM
    over60
    over60 "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Can anyone tell us what the MAXIMUM size should be for this plug socket?... I'd hate to tear everything apart and find out that MY socket does not fit....??
    Thanx...
    Over
  10. Feb 20, 2012 at 2:30 PM
    landphil
    landphil Wishin' I was Fishin'
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    A 5/8 craftsman, mastercraft... spark plug socket will fit just fine. If you try to use a 13/16, the bigger version, it won't go.
  11. Feb 21, 2012 at 5:16 PM
    over60
    Muskoka, Ontario
    I meant the outside diameter, not the inside socket size... We gotta use the 5/8" inside socket, but some guys say the outside dia. is important cuz a thick-walled one will not fit...
    Over
