Spark Plug Tubes on 3.4L
Discussion in '1st Gen. Tacomas (1995-2004)' started by sparkdawg, Dec 5, 2020.
  1. Dec 5, 2020 at 6:16 PM
    sparkdawg
    sparkdawg [OP] New Member
    2004 Tacoma
    Has anyone out there ever messed with the spark plug tubes on the 3.4L (5VZ-FE)? I'd like to know if they are pressed into the head or threaded, if anyone has ever pulled them out of the head and reinstalled, etc.
    My 2004 Tacoma tends to flood the #6 tube (driver's rear) with oil, even after the tube seals were replaced in conjunction with redoing the valve cover gaskets. I'm beginning to wonder if the problem tube is flooding from the bottom, as sometimes happens on older Camry engines.
    Thanks in advance,
    Bryan
  2. Dec 5, 2020 at 6:17 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
  3. Dec 5, 2020 at 6:19 PM
    Bishop84
    Bishop84 Well-Known Member
    They are pressed in and have small film of adhesive on them.
    My old boss used to use a 4x4 against the tube and whack them down if they leaked.
    Black DOG Lila likes this.
  4. Dec 5, 2020 at 6:34 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
  5. Dec 5, 2020 at 8:01 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Never seen them removed... but probably doable, likely will get ruined removing them. You need to use anaerobic sealant and press them in and measure as you go in.
    they are NOT threaded in like the old camrys
