spark plug wire replacement problem..HELP!
Discussion in 'Technical Chat' started by Chillyone, Apr 30, 2011.
  1. Apr 30, 2011 at 8:52 AM
    Chillyone
    Chillyone [OP] Member
    1996 Tacoma 4 x 4
    Just changed my plug wires on a '96 3.4 liter 5VZ and fired her back up, a bit rough starting and runs rough. Didn't run it much and did not drive it under load. I MIGHT have wired wrong as I was interrupted and had to come back to the job, and want to know which wires go to which cylinders.
    Any drawings or a format to which goes to which would be GREATLY appreciated.
    Thank you very much!
    Chillyone :D
  2. Apr 30, 2011 at 8:56 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to TW!
    Is this what youre looking for?
  3. Apr 30, 2011 at 9:14 AM
    Chillyone
    1996 Tacoma 4 x 4
    Thanks Chris! this is the firing order for 1996 3.4 5VZ. correct?
    Muchly appreciated my friend!!!!!
    Chillyone :)
  4. Apr 30, 2011 at 10:09 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Correct. And that also shows what wires go to what cylinders from teh coil packs.
  5. Apr 30, 2011 at 10:10 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You may also want to check to make sure you didnt disconnect any vacuum lines on accident.
  6. Apr 30, 2011 at 11:26 AM
    Chillyone
    1996 Tacoma 4 x 4
    Chris 4 x 4,
    A JUMBO "thank you" for your help..."got 'er done!" your diagram was all I needed....
    Cheers, I'm buying the suds!
    From Oregon....
    Chillyone :)
  7. Apr 30, 2011 at 2:14 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Glad to help! :)
