Spark Plug Wires?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 50180, Sep 6, 2011.
  1. Sep 6, 2011 at 8:28 PM
    50180 [OP] Well-Known Member
    Duluth, MN
    03 TRD DC 4x4
    Deck plate, grey-wire, blue plug, alarm mod, clear corners, moved/painted badges, color matched grill, topper, 5100s, wheelers 5 leaf + 1.5 aal , OME coils, All-Pro rear bumper, Methods w/ 32's, converted HID Hellas, supercharger
    I know the 3.4's have coil packs but I see rockauto has spark plug wire sets. How does this work? Does this just replace the wire going from the coil to the other plug? What about the coil pack itself? Is this something worth replacing after 170k miles?
  2. Sep 6, 2011 at 10:37 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    I don't think the coils are really a "wear" item... don't replace them unless you need to if one is bad.
  3. Sep 6, 2011 at 10:41 PM
    shampoop
    shampoop Well-Known Member
    southwest WA
    08 tacoma extracab v6 auto trd offroad 4x4
    No, you don't replace the coil packs unless they go bad. Maybe eventually replace the rubber insulators though.
    It sounds like you may not be aware that they only have 3 coil packs rather than 6. They use a waste spark system and have 3 standard plug wires running from the coil over plugs on the passenger side to the drivers side bank.
  4. Sep 7, 2011 at 6:15 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Check the coils for spark leakage if you suspect a ignition problem. Spray a water mist on the coils/wires in a dark garage while running the engine. Look for arcs. Any arc from the coil to ground? Replace the coil. Same goes for the wires.
  5. Sep 7, 2011 at 10:51 AM
    Duluth, MN
    03 TRD DC 4x4
    I don't have any issues and I know theres only three coil packs but is it a waste of money to replace the wires from the coils to the other plugs? I thought I heard somewhere that plug wires wear out somehow over time and should eventually be replaced, I could be making this up though.
  6. Sep 7, 2011 at 12:34 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Wires go bad. Some last longer than others. This is why I suggested the water test. Grey arc marks on the wire boots and wire will also show where there has been an insulation failure. Heat and oil kills wires.
  7. Sep 7, 2011 at 8:22 PM
    747 function > form
    1st Gen.
    buy some wires at napa and sleep better
  8. Sep 8, 2011 at 7:09 AM
    thatSchusterguy
    thatSchusterguy Well-Known Member
    Cincinnati, OH
    96 X-Cab
    OME/881 Dakars Demello HD sliders Marlin 1200# Clutch Rust and Duct Tape
    Fixed ;)
  9. Sep 12, 2011 at 5:29 PM
    yoTaco98
    yoTaco98 Well-Known Member
    Yo
    VA
    1998 V6 Xtra-Cab Tacoma 4x4 SR5
    5100's Front and Rears, Toytec Eibach Coils, All Pro 3" Standard Leafs, BAMF BPV Bracket, ARMA Sprayed Bedliner, TGD Hunter Bull Bar, Blacked-out Headlights and Corners, Revtek 1" Diff Drop, Start Command Remote Start and Keyless Entry, Pioneer DEH-11E HU...
    I think I should replace mine.
    When I bought the truck, the plugs needed replacing. When I went to change the plugs, they were so loose, they twisted off by hand with just a couple turns.
    On the boot/insulator on the front/drivers side cylinder is is loose. When I pulled up to remove the rubber insulator, the boot popped off the top rubber seal. The wires inside the boot didn't come a part, but the top rubber seal doesn't sit well on the valve cover anymore.
    I think my coil packs are ok, but I know may need to replace the wires/boots on the driver side.
    What do you guys think?
  10. Dec 13, 2011 at 10:38 PM
    x2468
    x2468 Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    Did you ever try the experiment skytower suggested?
    Btw thanks for the tip, im going to try this
  11. Dec 13, 2011 at 11:33 PM
    shampoop
    southwest WA
    But the NGK ones at napa are BLUE!!!!
  12. Dec 14, 2011 at 4:41 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Most of the dealer parts last longer than aftermarket. My plugs and wires are still going at 77k. I use wash down the engine bay and protect it with a spray down of WD-40 regularly. This helps protect wires, hoses and generally keeps corrosion to a minimum.
  13. Dec 15, 2011 at 11:22 PM
    shampoop
    southwest WA
    Do not listen to this. Never spray wd40 on anything that's rubber. It's a solvent. Just because some rubbers are good at resisting solvents and nothing bad has happened yet does not mean it's the right thing to do.
    If you want to lubricate any plastic or rubber items, use a silicone based lube. Petroleum based lubricants are in general not good for these kinds of items.
  14. Dec 16, 2011 at 10:01 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Seems to me that silicone spray has more powerful solvents than does wd-40. According to the msds, silicone spray contains trichloroethane which is a very powerful solvent:http://www.generalgraphic.com/msdssisp.htm. Wd-40, on the other hand, has some aliphatic hydrocarbons and base oils. I doubt they reach the solvent stregnth of tric though.
    I looked through other manufacturers of silicone spray. Some have no tric, some others use other base oils. So, yes, some silicone sprays are superior to wd-40.
    The stregnth and oil resistance of today's hoses is such that they deteriorate from heat before oils and solvents have an effect. If anything, both silicone, with solvents or oil, and wd-40 will keep hoses more pliable and less pront to craking than without.
    My point is, use whatever you like that performs the best in your climate/area. Wd-40 is easy to find in bulk, has worked well for me in the past, and it protects against corrosion. :)
  15. Dec 16, 2011 at 10:07 AM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    I had my plug wires go recently. Caused cylinder #4 to misfire. Not a good sound to hear from your engine. Change them before that happens
  16. Dec 16, 2011 at 11:02 AM
    shampoop
    southwest WA
    It's a pretty universally known thing. I never said you should shoot standard silicone spray all over your engine bay. Sure some manufacturers can add any kind of solvents you want to a silicone based fluid. It's not just about the solvents. You just never want to used anything petroleum based on plastics or rubber, always silicone based. Also, silicone based items do not attract dirt unlike petroleum based items.
