Spark Plug?
Discussion in '1st Gen. Tacomas (1995-2004)' started by SonoranDesertTacoma, Nov 25, 2023.
  1. Nov 25, 2023 at 2:26 AM
    SonoranDesertTacoma
    SonoranDesertTacoma [OP] New Member
    It’s time for the 200K service on my 3.4L Tacoma. Spark plugs have me a little confused … too many choices.
    Are the dual prong Platinums by Denso or NGK absolutely necessary? Can a single electrode Bosch do as well? What’s with the $5 difference between a dual prong Denso and a dual prong NGK?
  2. Nov 25, 2023 at 2:47 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    I stick with stock Denso’s.
  3. Nov 25, 2023 at 6:04 AM
    Av180r
    Av180r Well-Known Member
    Las Vegas
    1998 Tacoma SR5 V6 4x4
    Yes, only use the twin ground NGK or Denso.
    Maybe someone can correct me if this is wrong, but I think Toyota recommended replacing the spark plugs every 30k miles on the 5vz.
  4. Nov 25, 2023 at 3:15 PM
    Potomus Pete
    Potomus Pete Love my little truck
    Hippy
    Sarasota Florida The Great Place To Live.
    1999 Prerunner single cab. With a BO7A rear end
    All kinds 3 inch body lift/2 1/2 suspension lift. 31/11 1/2/15 tires All work done by myself for years. The only work performed by mechanic was fuel pumps. I also have a 90 Mustang 350 hp and I can never understand how come my Tacoma gets more respect Just got a 99 Jeep TJ that I rebuilt, and painted in the garage
    Rugular plugs..Nothing special
  5. Nov 25, 2023 at 4:31 PM
    Gen1andDone
    Gen1andDone Well-Known Member
    2002 4wd Tacoma TRD v6
    Dual prong only, Toyota specifies it for some good reason. I've used both part #'s called out in the manual, Denso and NGK. I've read some say the single ground plugs work fine but just wear out faster, others claim poor performance. Never felt the need to experiment for myself. The 3.4l plugs spark twice as often as some other engine platforms, supposedly under those conditions the dual ground plugs last longer.
  6. Nov 25, 2023 at 6:02 PM
    ztwatson
    ztwatson Well-Known Member
    Milwaukee, WI
    2004 Tacoma TRD Xtra Cab
    I used regular single prong spark plugs for 25k miles and they worked fine. Recently replaced with dual prong NGKs.
  7. Nov 25, 2023 at 6:21 PM
    Cheap Taco
    Cheap Taco Well-Known Member
    2001 Tacoma Limited Double Cab
    Spend the extra cash on the duals, like others have said denso or ngk
  8. Nov 25, 2023 at 6:46 PM
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, LonePeak wedge camper, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
