Spark plugs 2008 Taco 4.0L
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kilroy2963, Mar 17, 2023.
  1. Mar 18, 2023 at 8:02 PM
    Alealexi
    Alealexi Well-Known Member
    Houston, TX
    2007 Tacoma Prerunner
  2. Mar 18, 2023 at 8:35 PM
    Waasheem
    Waasheem
    2007 xrunner
    I thought for certain a bunch of people would chime in saying they used iridium and had problems.
  3. Mar 18, 2023 at 8:45 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I've seen iridium cause problems on other manufacturers. Not toyota but enough problems to keep me from straying away from stock.
    There may be some convenience to iridium lasting 100k. But how can you be sure the internal resistance "agrees" with the resistance of the ignition coil windings? What about the heat range? I don't pretend to know more than the toyota engineers. And I don't buy into the idea that "they use copper plugs to keep charging money for replacement every 30k". I'm also skeptical of gas mileage claims, usually mpgs have more to do with your right foot and tire size than plug selection
  4. Mar 18, 2023 at 9:04 PM
    99TacoDriver
    99TacoDriver Well-Known Member
    South Louisiana
    OME 885x/5100s/LR UCA/3 leaf AAL/275/70/17 Terra Trac X-Venture
    I got the platinum NGK 1483 in mine now. Regular copper plugs were not available when I went and they couldn’t tell me when they’d be available so I just settled for the platinum. They look odd with that tiny little electrode
    Pushing 200k miles and this is the first time it sees these kind of plugs. Been about 5k miles and every thing seems normal
    *edited*
    Thought I had iridium but checked again and they’re copper with platinum tips
  5. Mar 18, 2023 at 9:30 PM
    Pibbles99
    Pibbles99 One more cast
    Brian
    Southern NH
    21 OR dbl cab
    I agree. I change mine myself every 30k. They’re $4 apiece and takes me about 2 hours. So no biggie
    O'DubhGhaill and XSplicer62 like this.
  6. Mar 18, 2023 at 10:20 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    Your ignition system is designed for the lower resistance of copper. No other metal except silver (used in race cars) has better performance. Notice I said performance and not longevity. Engines made for platinum or iridium have higher voltages to push the current across the gap. Yes, it’s possible to use P or I plugs in copper designed ignition systems but you have a higher probability of misfires. Copper is going to give you a good fat spark as designed.
  7. Mar 18, 2023 at 10:44 PM
    burrito782
    burrito782 Shit Throwing Ape
    08 TRD Off Road
    Good man. :thumbsup: Just happy to see you didn't get the "Genuine" Toyota plugs off Amazon/Ebay...that is, genuinely made & counterfeited in China. :rofl:
  8. Mar 18, 2023 at 10:56 PM
    Nalex
    Nalex Well-Known Member
    2012 Tacoma DC TRD OffRoad
    My 2012 had about 50k miles when I changed them. And to my surprise one side had NGK and the other Denso. The Denso looked better.
    XSplicer62 likes this.
  9. Mar 19, 2023 at 3:43 AM
    Pibbles99
    Brian
    Southern NH
    21 OR dbl cab
    I get mine at the dealership. Nowhere else.
  10. Mar 19, 2023 at 3:50 AM
    Tacoma Mike
    Southern Maine
    How long are your naps between plugs? Lol
  11. Mar 19, 2023 at 3:56 AM
    Pibbles99
    Brian
    Southern NH
    21 OR dbl cab
    When I last changed my plugs ( at 122k), I found oil on the passenger side coil boots and a little on driver side, which means bad valve cover gaskets. So I changed those and the ignition coils with NGK coils. I needed to change my idler pulleys and assembly, and belt too as part of maintenance as I noticed they were noisy. The next week it was my alternator. Engine is running like brand new.
    O'DubhGhaill and Tacoma Mike like this.
  12. Mar 19, 2023 at 3:58 AM
    Pibbles99
    Brian
    Southern NH
    21 OR dbl cab
    I’m certainly not breaking any records as far as speed goes :rofl:. I get it done though
    :thumbsup:
    Tacoma Mike[QUOTED] likes this.
  13. Mar 19, 2023 at 4:00 AM
    Tacoma Mike
    Southern Maine
    :fistbump:
    That’s what it’s all about..
    Pibbles99[QUOTED] likes this.
  14. Mar 19, 2023 at 4:04 AM
    Pibbles99
    Brian
    Southern NH
    21 OR dbl cab
    What’s this MAF sensor look like? Is that something that should be part of preventative maintenance like the PCV valve I changed out recently?
  15. Mar 19, 2023 at 9:35 AM
    #35
    XSplicer62
    XSplicer62 Well-Known Member
    Jefferson State
    2005 Tacoma DC TRD OffRoad
    Only 110K miles on our 2005 and I have put in new copper plugs 3 times since we bought it new
    Yep, three of each seems to be standard procedure at Toyota. I replace mine with six Densos at each 30K change.
  16. Mar 19, 2023 at 12:12 PM
    #36
    Waasheem
    Waasheem
    2007 xrunner
    Back when I only maintained my own stuff, I thoroughly enjoyed doing it. I'd scrub every fastener removed with wd40 and a toothbrush, put it back in with anti seize or thread lock or thread sealer. Cleaned everything within arms reach of what I was working on, replaced anything I felt like a new one was needed.
    Now that I maintain other peoples stuff for a living, it just feels like more work. I'm still more meticulace with my stuff than a customers.
    I believe it's in the stickies, what to do, what not to do, what cleaner to use.
  17. Mar 19, 2023 at 4:34 PM
    #37
    XSplicer62
    Jefferson State
  18. Mar 19, 2023 at 5:11 PM
    #38
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    About 80k miles between naps :anonymous:
    Hey, I never said I follow my own advice. :rofl:
    Pibbles99 and burrito782 like this.
  19. Mar 19, 2023 at 5:29 PM
    #39
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Lots of varied opinions on plugs so here is another that states iridium's are better so.....
    13 Advantages and Disadvantages of an Iridium Spark Plug – Green Garage (greengarageblog.org)
    Another
    Iridium vs. Platinum Spark Plugs - In The Garage with CarParts.com
    Another
    Iridium Spark Plugs: Benefits & FAQs | RepairSmith
    So all state less voltage and more durable and many advantages with only the cost a negative.
    Manufacturers often use the cheaper option to save money plus 2gens are older and plugs have advanced over the years.
    You all can read so make your own decision.
    Pibbles99 likes this.
  20. Mar 19, 2023 at 5:36 PM
    #40
    TnShooter
    Deogee
    STOCK
    In terms of plugs. Yes, iridium is better.
    In terms of performance, that’s not always the case.
    Typically you won’t have any issues, but on occasion you will.
    And the the 4.0 can be an “occasion”. Therefore, I try to advise people to stick to the OE plugs.
    Williston and O'DubhGhaill like this.
