Spark Plugs 4.0
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hardtaco, Nov 14, 2016.
  1. Feb 8, 2018 at 7:40 PM
    #41
    gnorv
    gnorv Member
    No. It’s a spark plug...don’t over think it. Iridium last longer than copper which is why I changed to iridium. I have run mine for 30K and I can tell zero difference. I ran copper when drag raced a 68 firebird and currently run copper in my KTM 2 stroke because I change the plugs more often.
  2. Feb 9, 2018 at 7:44 PM
    #42
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    As long as your gas mileage isn't any worse, I'd let them go. Years ago, I replaced plugs in a GMC pickup I had. It had the platinum plugs in it and that was OEM but they were eight bucks each. I didn't want to spend fifty bucks on plugs so I bought iridium or something of the sort. It ran smooth but seemed down on power. After a couple of fill ups, I noticed my gas mileage had dropped a couple of miles per gallon.
    I went back and spent the fifty bucks and replaced them again. Then it was back to normal.
    Gas mileage check is a good indicator.
  3. Nov 21, 2018 at 10:51 AM
    #43
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    I have been getting 420 miles per tank since purchased new. Now have 202k miles on original plugs.
  4. Feb 1, 2020 at 7:57 PM
    #44
    EmissionsAreNotAnIssue
    EmissionsAreNotAnIssue New Member
    2006 Tacoma 4x4 double cab
    2 inch lift. Custom exhaust. Gutted cats on stock manifold.
    I have a 2006 Tacoma 4x4 with the 4.0. I put NGK iridium plugs in it not long after I got it in 2018 at 95k miles. After about 3-6k miles I'm not sure. My truck started to run rough so I bought so Denso double iridium plugs cause the NGK jumped gap and were bot firing properly. So if you go iridium I strongly suggest Denso. Jmo
  5. Feb 2, 2020 at 6:20 AM
    #45
    EdgemanVA
    EdgemanVA Well-Known Member
    Virginia Beach
    2008 X-Runner
    Several
    I stick with "standard" plugs and swap them every 30K miles. That gives me a chance to inspect the plugs to see how my truck is running. It's not a bid deal, since I don't mind swapping plugs that often.
    But if you prefer to minimize your routine maintenance, go ahead and switch to iridium plugs. They should be good for at least 90K miles.
  6. Feb 2, 2020 at 9:55 AM
    #46
    Greenedmc
    Greenedmc Well-Known Member
    Daniel
    Elizabethton TN
    2014 Silver Tacoma Trd Off Road Access cab
    Be careful if you buy plugs on Amazon or eBay.. I never knew people counterfeited those. I purchased oem sensor plugs on eBay and within 10k miles I had a center electrode brake and cause a misfire.:annoyed:
    #46
