Spark plugs and tranny fluid
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LeadFootCaliKid, Mar 4, 2010.
  1. Mar 4, 2010 at 1:23 PM
    LeadFootCaliKid
    LeadFootCaliKid [OP] It's a work in progress.
    Blake
    Temecula/North SD
    2005 DC PreRunner TRD Off-Road
    Total Chaos UCA's, Icon coil-overs, Icon gas reservoir rear shocks, Eagle Alloy 17", Nitto Terra Grappler 285/75/17, Flowmaster 40, Kenwood deck, and dual 10" Kicker subs, shorty antenna. There's more...
    It's time to change my spark plus and transmission fluid. What are the best spark plugs to get? Any recommendations for the tranny fluid?
    Thanks.
    NEW QUESTION: I've found the DIY for the full flush for auto transmissions, but that requires 14 quarts of fluid! I only bought and want to pay for the needed 4 quarts. What do I do?
  2. Mar 4, 2010 at 2:15 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    WS fluid for the auto tranny, and the OEM Denso plugs listed in my spark plug write up.
  3. Mar 4, 2010 at 2:28 PM
    LeadFootCaliKid
    Blake
    Temecula/North SD
    What is WS?
  4. Mar 4, 2010 at 2:29 PM
    NAAC3TACO
    NAAC3TACO Well-Known Member
    Sparks, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Toyo A30 tires, Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts.
    I believe it's World Service. It's used in the 5 speed auto. The four speed auto still uses Type IV.
  5. Mar 4, 2010 at 2:39 PM
    LeadFootCaliKid
    Blake
    Temecula/North SD
    Are there no "performance" spark plugs?
    World Service is a type of fluid? Is there a certain brand or anything?
    Where is the cheapest place to get it from?
  6. Mar 4, 2010 at 2:39 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I heard "World Standard" or "World Synthetic".....:confused:
  7. Mar 4, 2010 at 2:42 PM
    LeadFootCaliKid
    Blake
    Temecula/North SD
    Isn't synthetic better? Is the WS synthetic?
  8. Mar 4, 2010 at 2:44 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Modern Coil on Plug ignitions all ready put out a shit ton of voltage. Platinum, or Irridium plugs only benafit the force inducted engines. And mulitiple ground plugs are a gimmick. Electricity is going to follow the path of least resistance. Multi tipped plugs may look good in pictures, or in an animation, but they do nothing more than the OEM nickle/copper plugs. Some people have even had the CEL come on when useing different plugs.
  9. Mar 4, 2010 at 2:54 PM
    LeadFootCaliKid
    Blake
    Temecula/North SD
    ...yes? Haha. Seriously though, I'm still a little confused. Is WS just a type of atf that several companys make? What is WS?
    Very helpful. Thank you. I need to go through Toyota to buy those right?
  10. Mar 4, 2010 at 2:58 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    X2
    I think Amsoil is the only brand that has a compatible product (specs wise).
  11. Mar 4, 2010 at 3:00 PM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    WS Buy it at the dealer for peace of mind.
  12. Mar 4, 2010 at 3:04 PM
    NAAC3TACO
    Sparks, NV
    2014 SR5 DCLB 4x4
    You may be right.
    EDIT. Looks like you were right about World Standard.
  13. Mar 4, 2010 at 3:18 PM
    hate2work
    hate2work Well-Known Member
    Washington State
    06 standard cab
    Both the Amsoil ATL and the Red Line D6 are compatible, and are both superior products to the Toyota fluid. You can buy gallons of the D6 on Amazon.
  14. Mar 4, 2010 at 11:23 PM
    LeadFootCaliKid
    Blake
    Temecula/North SD
    Any arguments?
  15. Mar 8, 2010 at 7:24 PM
    LeadFootCaliKid
    Blake
    Temecula/North SD
    Tranny fluid and spark plugs have been purchased. But I have new concerns regarding changing my atf. Please answer my "new question" at the top.
    Thank you.
  16. Mar 8, 2010 at 7:27 PM
    RDAY
    RDAY Well-Known Member
    NY
    07 Tacoma SR5 4x4
    where exactly do u ass the fluid i dont see a dip stick to check the tranny fluid levels how do u check them?
  17. Mar 8, 2010 at 7:43 PM
    hate2work
    Washington State
    06 standard cab
  18. Mar 8, 2010 at 8:03 PM
    RDAY
    NY
    07 Tacoma SR5 4x4
    i have an 07 automatic is that a 5 speed auto that ur talking about also i meant add not ass lol
  19. Mar 8, 2010 at 8:11 PM
    tacobo670
    tacobo670 if you have to ask, u can't afford it
    Ray
    Las Vegas
    Tacoma Sport 4x4 AC 6spd
    Super cherry n some champion stuff on the side
    if u look on the passenger side of the tranny right before the end of the case (right before the "snout") there is a 24mm plug. that is the fill hole. u need some sort of pump like in the previous pic. the other 2 plugs are on the trans pan. one is the drain plug and the other is the "overflow" plug. vehicle must be running at at operating temp for proper fluid exchange. its a little tricky to perform the whole service.
    technically the WS (world standard) is a 100k mile fluid and does not need to be service till this mile interval.
  20. Mar 8, 2010 at 9:34 PM
    nuckinfuts
    nuckinfuts NyQuil on the rocks.
    Pacific NW
    '06 AC TRD Off-Road
    DT Long Tube Headers, Empire O2 simulator, catback, Shrockworks Sliders, Old Man Emu 3" lift with 885 coils (with 1/2" top plate spacer and Dakar Leaf packs), Hi-lift mounted in bed with 4XRAC mounts, WT floor liners, other stuffs
    It's not too hard to get the trans into temp check mode, before you start draining fluid try it out a few times to be sure you can do it correctly. Keep in mind the Toyota WS fluid is $7-8 a quart and you'll need around 3-4 quarts to do the drain/refill. My plan is to change it over the next couple oil changes to eventually get a good amount of new fluid in there.
