Spark Plugs Due at 30k?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by flesheatingvirus, Feb 25, 2018.
  1. Jan 29, 2019 at 10:33 AM
    #81
    r1200gs4ok
    r1200gs4ok Well-Known Member
    O. K.
    Irvine, Ca
    2016 Tacoma TRD Sport DCLB w/ Tech, Nav, Tow Pkg, MGM
    changed at 150k....gap was fine, tight but not frozen....new plugs installed and running just like before.....i’ll not go that far on the truck and will change at 60k.....not advocatng that long of an interval but I’m my case it did not hurt anything
  2. Jan 29, 2019 at 10:51 AM
    #82
    G500xl
    G500xl Member
    Buda, TX
    07 DC PreRunner
    I called one Toyota Dealer they quoted me $419 (change at 100K) and then I called another one $175 (Change 60K). Looks like I'll be doing the job myself once it's time.
  3. Jan 29, 2019 at 11:32 AM
    #83
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Guess I got a great deal at Lexus dealer. The only reason I had Lexus do GS 350 is, super tight in there compared to Tacoma. Intake removal was a must on GS. Same as IS 350 I had before GS.
    Unreal the two different price you were quoted. FYI - Plugs (old) in GS, and IS looked perfect, and gap was perfect.
  4. Jan 29, 2019 at 3:05 PM
    #84
    Dirtridercrf250
    Dirtridercrf250 Well-Known Member
    Just hit 80k and will be changing the plugs this weekend along with a new rubber o-ring gasket for the intake manifold. I did not change it the first time and is a good preventive measure to just replace it.
  5. Jan 29, 2019 at 3:51 PM
    #85
    Tacoesh
    Tacoesh Well-Known Member
    Don't waste your money at 30k, it will be fine using Toyota's service schedule, not the dealer's...
  6. Jan 29, 2019 at 7:03 PM
    #86
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    again, you don't have to remove the intake mani on a GS350 either. just the intake pipe (same as the 3.4). I did mine in under an hour...
    But 125 is a good deal. the plugs themselves cost over half that. they quoted me $400!
  7. Jan 29, 2019 at 7:25 PM
    #87
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    $175 is fine if it includes parts and labor. Think of it this way, If anything gets messed up, better the dealer than you or some other shop.
    Sdswingr likes this.
  8. Jan 29, 2019 at 8:03 PM
    #88
    Amanelot
    Amanelot Member
    Texas
    2016 MGM TRD Sport DCSB
    Lolwut
  9. Jan 29, 2019 at 8:05 PM
    #89
    Amanelot
    Amanelot Member
    Texas
    Damnit. You're an ass. Lol
  10. Jan 29, 2019 at 8:09 PM
    #90
    friendlywithbears
    friendlywithbears a tree falling in the woods
    B
    The Wild
    2016 TRD OR MT
  11. Jan 29, 2019 at 8:09 PM
    #91
    Amanelot
    Amanelot Member
    Texas
    I'm bad at this, sorry.
    3rd gen forum has changed.
  12. Jan 29, 2019 at 8:13 PM
    #92
    friendlywithbears
    B
    The Wild
    2016 TRD OR MT
    I CAN'T BELIEVE YOU ARE SPREADING THIS LIES WHAT ARE YOU THINKING THERE IS NO SUCH THING AS BREAK IN SPARK PLUGS. TYPICAL 3RD GEN ASSHOLES. NO WONDER NOBODY LIKES ANY OF YOU.
    Running Board Man likes this.
  13. Jan 29, 2019 at 9:20 PM
    #93
    G500xl
    G500xl Member
    Buda, TX
    07 DC PreRunner
    I called another dealer in the area and their price was $583.50!! I just laughed when they told me.
    Running Board Man and shakerhood like this.
  14. Feb 12, 2019 at 4:56 PM
    #94
    r1200gs4ok
    O. K.
    Irvine, Ca
    went to dealer today to review whats done at 30k service......the showed me three versions:
    1..Basic Service.....$286.95
    chk floor mat install
    rotate tire
    replace engine oil and filter ( $37.00 / $5.95)
    replace air filter ($27.95)
    replace cabin filter ($17.95)
    inspect engine/inverter coolant
    inspect rack & pinion
    inspect radiator
    visually inspect brake lining and drums and pads and disc
    inspect and adjust all fluids
    inspect wiper blades
    multi-point inspection
    parts: $87.00 ~$200 labor
    2..Value service.....$521.95......same as basic with the following:perform a/c refresh service
    service battery and run Midtronic's test ???
    install washer solvent ???
    pressure wash engine bay ???
    check alignment ($149.95 separate) doesn’t mean they will do it....just check
    difference: $231.00 over Basic
    3..Premium Service $1107.95.....same as basic and value service with the following additions:
    torque bolts and nuts on chassis and body
    run health check and provide print out
    perform brake fluid exchange ($189.95)
    perform throttle body service ($189.95)
    clean induction system ($197.95)
    perform alignment ($149.95)
    difference: $586.00 over Value service
    oil filter...............5.95
    air filter.............27.95
    cabin filter.........17.95
    Mobile 1 0/20....37.00
    I can do the Basic and save $200
    I can do Value for $236.95 and save and save $285
    The Premium is a little bit different.......do I really need brake fluid exchange (fluid is clear to slightly yellow)?......do i really need throttle body and EFI service?..........truck is running straight and true, no shimmy...... tires have never been balanced and are wearing very good and straight across, over 3/4 tread left after 29K.......
    do I really need the premium service?....i don't think so, because I can do most of the stuff myself.......but would like you guys input
    thanks in advance
    OKU
  15. Feb 12, 2019 at 5:20 PM
    #95
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I would do it yourself, even that Basic Service is not much more than just an Oil Change and a Tire Rotation for $300.
  16. Feb 12, 2019 at 5:21 PM
    #96
    r1200gs4ok
    O. K.
    Irvine, Ca
    yea thats what I thought too....
    shakerhood[QUOTED] likes this.
  17. Feb 12, 2019 at 7:09 PM
    #97
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    If you are not going to change your plugs like some say on here then you better loosen them once in a while because they can get crazy tight .
  18. Feb 12, 2019 at 7:16 PM
    #98
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Don’t give the dealer a damn penny.
  19. Feb 12, 2019 at 7:22 PM
    #99
    shakerhood
    Southern Ohio
    They should be fine changing at the recommended 60K intervals.
  20. Feb 12, 2019 at 7:23 PM
    #100
    r1200gs4ok
    O. K.
    Irvine, Ca
    my thoughts exactly
