spark plugs & engine cleaning
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kristi with a K, Jun 14, 2021.
  1. Jun 15, 2021 at 12:51 PM
    JudoJohn
    JudoJohn Well-Known Member
    St. Louis
    96 Tacoma 2WD 5 speed
    That's what I would do if I were in your shoes. A good shop vac is you friend.
  2. Jun 16, 2021 at 4:55 AM
    1997tacomav6
    Denver
    That sounds like a good plan
  3. Jun 16, 2021 at 2:29 PM
    Old n' slow
    Old n' slow Well-Known Member
    Oak Island, N.C.
    2000 Tacoma 2.4 5 speed flare side
    I still have a bunch of copper plug washers from decades ago.....we used to change them all the time when cleaning and re gapping plugs. “They do get compromised” but unfortunately I can’t even get the washers off the new style plugs ☹️
  4. Jun 21, 2021 at 10:37 AM
    Kristi with a K
    Kristi with a K [OP] Well-Known Member
    Western MA
    01' Black (was Maroon, then red) Tacoma 4x4 SR5 ACab 3.4L AT
    G-Men sticker, driver's side "backseat" window - cracked driver's side headlight cover complete with hazy look - DIY 30 footer paint lift in Bedliner Black
    So as I am doing this, I i’m taking it this is more than “two bolts”? A nut plus knock sensor connections? Plus that foam seal is going to probably rip more.
  5. Jun 21, 2021 at 2:18 PM
    Kristi with a K
    Western MA
    I figured it out. Each plastic thing snapped? sorta. It was as though they were ready to go. So hopefully electrical tape around the connections & a zippy or two to attach the harness to the pipe will suffice. Oh, & the foam thing actually stayed in tact.
    1997tacomav6 likes this.
  6. Jun 21, 2021 at 2:29 PM
    1997tacomav6
    Denver
    You might want to replace the knock sensor wire harness since your there,
    It cost 20.00 or so and are under ALOT of stress from the heat there
