Spark Plugs Every 30K Necessary?
Discussion in 'Performance and Tuning' started by Roccoaverto, Jul 20, 2012.
  1. Jul 20, 2012 at 8:48 PM
    Roccoaverto
    Roccoaverto [OP] Member
    Rocco
    Scranton, PA
    07 TRD SR5 Double Cab
    I have a 2007 double cab 4x4 4.0L engine . The service manual calls for new spark plugs every 30k miles. I changed them at 30K using 3 NGKs and 3 Densos and saw no difference in performance or gas mileage. Now at 70k miles I am overdue. Gas mileage ( 19 mpg average ) and performance are no different than at 30K. Aside from keeping the emissions warranty in effect, why change plugs every 30k miles? Thanks in advance !
  2. Jul 20, 2012 at 8:50 PM
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    tint, dents, scratches, two blown speakers and trying to pay her off...
    108,000 miles on my 07 4.0ltr. . 20k of them by me. think i still have stock plugs :anonymous: :eek:
  3. Jul 26, 2012 at 6:20 PM
    yota14
    yota14 Well-Known Member
    Nathan
    Concord, North Carolina
    1996.5 Tacoma 4wd 6cyl 5spd
    TRD SuperCharger 6in TrailMaster Diff Drop 3in BLift Flow Master Exhaust Sony Explod Radio Pioneer Speakers Rear & Front 2 JL Audio 10" Subs Apline Amp Toolbox Westin Step Bars Vent Visors
    I just changed my spark plugs in my 5vz-fe and it had 112k miles and stock plugs. They were starting to get bad. My cousin had 135k on his when his started to go bad.
  4. Jul 26, 2012 at 6:23 PM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    Ask Whippersnapper about how great the E3 sparkplugs are, if you want to talk about performance.
  5. Jul 26, 2012 at 6:36 PM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    These days you get a lot more out of your plugs, and the ECM helps get even more from there. 75K is a good number but you CAN wait longer.:D
  6. Jul 26, 2012 at 6:40 PM
    BradleyScottETC
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    All joking aside, if the manufacturer suggests 30k for best performance and it costs less than $15 and takes less than 15 minutes, why the hell wouldn't you do it?
  7. Jul 26, 2012 at 6:50 PM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    15 minutes? Holy smoke you must be a knuckle dragger speed demon.
    I could do my last Honda in 15, but that was just 4 bolts for the coil packs.
    The 4.0L, pass side took 5 minutes, and the driver's side took an hour and a half. Word of advice, don't drop your 10mm socket into the frame crossmember when trying to bolt down that utterly retarded clutch hardline support bracket (why did they bolt the clutch line to the intake manifold anyways?!?!).
    I had about 32k or so when I changed them and the NGKs were quite worn, one of them over 0.060" gap. The Densos were much better, the widest of them was 0.048" iirc. If only I'd have known BEFORE I bought a half dozen NGKs.
  8. Jul 27, 2012 at 12:09 AM
    6spd
    6spd Well-Known Member
    san diego
    2012 4x4
    I always changed my plugs in previous vehicles every year, just so they wouldnt get stuck to the block. I dont drive as much as I used to, so I think I'll stretch it out to two years, regardless of mileage
  9. Jul 28, 2012 at 6:41 AM
    ManMan
    ManMan Well-Known Member
    Put a little anti-seize on the threads and you'll be good to go for the recommended maintenance interval
  10. Jul 28, 2012 at 8:22 AM
    Speed Freek
    Speed Freek Turbo lover!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Currently under the knife for turbocharger..
    What!? Always use the same plugs on both sides, the reason you might think it is supposes to be that was is because the factory had the heads built a 2 seperate factories, and somebody didnt get the memo on what plugs to use....
    I run denso plugs, and recommend changing them every 30-40K miles, they really dont take long to change, and not that expensive
    By 75K you plug gap should have increased by roughly 25%+, doesnt that mean a bigger spark? Well kinda, but not really. You want the recommended gap for proper operation, its going to work much better..
  11. Aug 1, 2012 at 11:57 AM
    cms
    cms Active Member
    Good thread, I just had the same question!
    What kind of oil does Toyota use?
