Spark Plugs for 4 Cylinder 2.7 Engine
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wingspar, Apr 22, 2024.
  1. Apr 22, 2024 at 6:15 PM
    wingspar
    wingspar [OP] Well-Known Member
    Oregon
    2011 Tacoma 4x4 Access Cab
    I asked a question in the spark plug part of this forum, but got no response even tho others posted questions after me. It seems like everything I’ve ever seen about spark plugs in this forum are about the 6 cylinder engines that have two different brands of spark plugs, but does that hold true for 4 cylinder engines also, or are all 4 plugs of the same brand ok. I had a V6 in my older 1993 SR5 but didn’t feel like spending the extra money for the v6 when I bought my 2011 brand new.
    Till I read about plugs in this forum, I had never heard of Denso Plugs before and people seem to rave about them. My question is are all 4 plugs supposed to be the same brand or should I use two of one brand and two of another? If all one brand, I’m considering Denso’s.
    Robnik likes this.
  2. Apr 22, 2024 at 6:25 PM
    Finbox
    Finbox Well-Known Member
    Tim
    15' access cab 4x4
    I have a 2015 4 banger- got the Denso Iridium Plugs from RockAuto - all 4 the same. I think the Denso plugs are the OEM supplier - No Complaints, but its not Friday.
  3. Apr 22, 2024 at 6:28 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Robnik and wingspar[OP] like this.
  4. Apr 22, 2024 at 6:28 PM
    216to404
    216to404 Well-Known Member
    2006 RC prerunner
    I just replaced the plugs on my 2.7. They were the original plugs, and all 4 were denso iridiums. I installed new denso iridiums right back in their place.
  5. Apr 22, 2024 at 10:21 PM
    wingspar
    Oregon
    Thank you for the replies. 4 Denso Iridiums it will be. I have about 56k miles on the original plugs. It’s probably time. Runs a little rough at idle.
    Robnik likes this.
  6. Apr 22, 2024 at 10:54 PM
    Robnik
    Robnik Disciplined Maniac
    Rob
    Greenacres, Florida
    2012 Base Reg Cab 2.7L 2TR-FE A340E
    You'll be good with Denso.
    I prefer NGK, but that's just me. :)
    wingspar[QUOTED][OP] likes this.
  7. Apr 22, 2024 at 11:17 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    OEM plugs bro. Did the 11’s come with iridium?
  8. Apr 23, 2024 at 6:24 AM
    snowdrifter
    snowdrifter Well-Known Member
    Indiana
    11 SR5 AC 4x4
    If it's running rough at 56k miles, I doubt new plugs will help. They're supposed to be good for 100k miles. Not trying to discourage you from changing them, it's a relatively cheap and easy swap and peace of mind.
    I swapped out my originals a year ago.
    https://www.tacomaworld.com/threads/how-to-change-sparkplugs-2tr-fe.157316/page-9#post-28653884
    Jimmyh likes this.
  9. Apr 23, 2024 at 6:45 AM
    Finbox
    Tim
    15' access cab 4x4
    With the rough idle - try cleaning the MAF sensor and PVC valve. Both easy & cheap.
  10. Apr 23, 2024 at 7:11 PM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    I've done both the denso at 100k and ngk at 200k.
    Both sets were great, wore evenly and I have no complaints.
    wingspar[OP] likes this.
  11. Apr 23, 2024 at 10:08 PM
    wingspar
    Oregon
    I have no idea. Does anyone know?
  12. Apr 23, 2024 at 10:20 PM
    wingspar
    Oregon
    I read somewhere recently that rough idling was caused by plugs and they have about 56k miles on them. I’m not a mechanic, so my knowledge is limited.
  13. Apr 23, 2024 at 10:21 PM
    wingspar
    Oregon
    Might try that. I saw a thread the other day that had everything under the hood labeled if I can find that thread again.
  14. Apr 24, 2024 at 12:56 PM
    tak1313
    tak1313 Well-Known Member
    2013 Base 2WD
    Denso! But @ 56K, they SHOULDN'T be the problem (but it's not like it never happens). Are there codes? What is "runs a little rough at idle?"
  15. Apr 24, 2024 at 12:58 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    Stock
    If they were Amazon Denso’s then they could be bad at 56k
