Spark plugs for a 2008 taco crew cab?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by smcgill, Aug 19, 2014.
  1. Aug 19, 2014 at 2:47 PM
    smcgill
    smcgill [OP] Well-Known Member
    Sean
    South Easton Mass. not enough time in Cocagne NB
    Camry and Ram 1500 with a "HEMI "
    What are the majority using for spark-plugs?
    I have 221,000 miles and I might need to replace original plugs.:eek:
    Should I also replace the wires?:notsure:
  2. Aug 19, 2014 at 2:55 PM
    DPC08
    DPC08 Well-Known Member
    FL
    09 DCSB
    Getting there...
  3. Aug 19, 2014 at 2:56 PM
    1eyedjack
    1eyedjack Old Pirate
    Southeast USA
    2014 MGM DCSB TRD Sport Tow
    OEM plugs and wires plus having the injectors cleaned but that is just me.
    Have you kept up with the recommended service items listed in the manual?
  4. Aug 19, 2014 at 3:48 PM
    hotrod53
    hotrod53 Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    I use OEM Densos, there are no wires, you have individual coils.
  5. Aug 19, 2014 at 3:50 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    If it's anything like mine a many others. You're going to have to need 3 NGK and 3 Denso plugs if you go OEM. Why they come that way from the factory? I have no idea.
    I choose to go with 6 Denso. I forgot what the number was on the plug.
    I got the number from my owners manual. The plugs seem to run fine.
  6. Aug 19, 2014 at 3:55 PM
    outdoorgb
    outdoorgb (.)(.)
    Burbs of Oregon
    2014 DCSB TRD Sport Silver Sky...
    For the V6 the plugs are like $2-$3 each. Go to a dealer and tell them you want six of them.
    Wires - I'd replace if exposed to high/cold temps, humidity, dust, etc much over the 220K miles
    Post pics of the original plugs....
  7. Aug 19, 2014 at 3:59 PM
    smcgill
    Sean
    I will try!:p
  8. Aug 19, 2014 at 4:04 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    OEM denso.
    you DO NOT need 3 denso and 3 NGK!
  9. Aug 19, 2014 at 4:06 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    :cool:
  10. Aug 19, 2014 at 4:29 PM
    TnShooter
    Deogee
    STOCK
    I understand that. I quoted the guy before me that said "Go OEM"
    What I was trying to state is that Toyota went OEM with 2 DIFFERENT plugs in a lot of the 4.0 engines for no known apparent reason?
    Further more, I was also letting the OP know not to be concerned if he finds
    2 different plugs in his truck.
    Choose an NGK or Denso in a quantity of 6 and all will be fine.
  11. Aug 19, 2014 at 4:34 PM
    TnShooter
    Deogee
    STOCK
  12. Aug 19, 2014 at 4:36 PM
    asuchemist
    asuchemist My Hamstrings Hurt!
    South South Dirty Gilbert
    11' TRD Sport V6, 23' TRD Pro 4Runner, 23' Tacoma TRD Pro
    NONE
    dang mine replaced at 30K with originals.
  13. Aug 19, 2014 at 5:50 PM
    Mr.Gadget
    Mr.Gadget Well-Known Member
    NC
    2011 DC 4x4 SR5 SB/2012 DC 4x4 SR5 LB(sold)
    I would like to see some pictures of new vs 30 k plugs or 40-50 k for some of you that go to that.
    I can not see why they would use the different plugs per side, if you have the dealer do it they do not, and also other service centers call for a different brand.....
    Wonder if a better plug would help power and MPG?
    Anyone played with some of the others or plugs that will go 100k
  14. Aug 19, 2014 at 8:37 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Supercharged calls for 100K
  15. Aug 22, 2014 at 12:48 PM
    smcgill
    Sean
    Replacement with Toyota's plugs went well!
    All bolts backed off nicely, coils and it's wire harness separated easily!
    Plugs I just took my time and they weren't to bad to remove.
    I'm glad I have a long extension!
    So @ 221,500 miles this is what the worst looked like, opposite the new ones!
  16. Aug 22, 2014 at 3:05 PM
    outdoorgb
    outdoorgb (.)(.)
    Burbs of Oregon
    Gap looks about 2x nominal but the ceramic looks normal...
    Check your milage...of course you'll probably throw a code now when the ECM says "WTF is this shit man?":)
