Spark plugs, whose changed em? what kind?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 209taco, Oct 27, 2014.
  1. Oct 30, 2014 at 11:10 AM
    Mr. Biscuits
    Mr. Biscuits gentleman and a scholar
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    - OME 881s, Dakars + D43XL - Custom front tube bumper - 33x10.5R15 BFG KO2s - Deckplate mod + Airaid intake tube + AFE reusable air filter - Aero Turbine 2525 exhaust, chopped before leaf spring - Toyota Horns emblem by Diaz Fabrication - BOSS CarPlay head unit, 500W amp + 12" Pioneer in ported box - camper shell
    while I previously posted in reference to a recommendation to not use dual electrodes, it has come to my attention that a quite large and imposing sticker on the engine specifically states to use dual electrode plugs.
    duh.
  2. Oct 30, 2014 at 10:02 PM
    2RZFE
    2RZFE Well-Known Member
    Denso K16R-U gapped at .028 in my 99 2.4
    The NGK V-Power BKR5EYA gapped at .032 is another good choice for a stock engine.
    The G-Power made my engine sound rough.
    The Iridiums are a waste of money.
  3. Oct 31, 2014 at 7:28 AM
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    I have a 2.7 in a 4X4 Tacoma. I just changed mine and put in the NGK iridiums mainly because they last the longest. Didn't notice any difference whatsoever from the Denso's that were in there and the iridiums. Iridium actually doesn't conduct as well as coper or platinum but it outlasts them both. I don't want to have to pull my plugs every 30,000 miles although I probably will pull them after about 50,000 just to check the gap and make sure they don't become one with the head.
  4. Nov 11, 2014 at 8:45 AM
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    Anybody else notice less annoying ticking noise after changing out 3 of one plug and 3 of another plug on each side?
  5. Nov 11, 2014 at 11:40 AM
    209taco
    209taco [OP] Member
    Sid
    Central valley California
    2004 tacoma trd 5 spd 3.4L
    grey wire, leer camper, tundra brakes
    I have been running single pole plugs on my truck and so far all is good...
  6. Nov 12, 2014 at 10:56 AM
    JAGER91374
    JAGER91374 Well-Known Member
    Des Plaines
    3 TRD O/R
    OME 883's and Dakars, OME Shocks, Gray Wire, Deck Plate, Blacked Out Chrome, RAT Skids, BAMF BPV Bracket, Toytec Diff Drop, Braided Extended Brake Lines Front and Rear, In-Dash Nav.
    Not all of them. My 03 had 6 Denso's in it from the factory. I swapped mine out for factory Denso replacements at around 60K and again at 100K. They were burnt down to nubs after the first 60K so I did them sononer the second time and they looked pretty good when swapped.
    Getting ready to swap them again this weekend as I know have about 140K on the odo.....
  7. Nov 12, 2014 at 5:32 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    I learned a long time ago that unless you have a hopped up tricked out motor to take advantage of the small difference those expensive plugs give you, then just buy the normal regular stock spark plugs and they work just as good and last just as long as the pricey plugs with fancy names and special electrodes will.
    anything beyond basic stock plugs is just wasted money but if it makes you feel better about it to use iridium or two or more electrodes then to each his own
  8. Nov 12, 2014 at 5:55 PM
    Robb235
    Robb235 Well-Known Member
    Chattanooga, TN
    1999 Turbo 4Runner
    Turbo 5vz uaEFI Standalone ECU 231mm Tundra Brakes RR Diff Lock Hayden 699 Transmission Cooler
    Yeah, those engineers also slapped an undersized supercharger on the 5vzfe with no tuning or upgraded fueling, and called it good. So let's not start with that crap. Just because the engineers at Toyota did it one way doesn't necessarily mean that's the best way.
  9. Nov 12, 2014 at 7:43 PM
    keakar
    karl
    louisiana
    agreed, they do things more for monetary reasons then for true performance, function, or reliability
  10. Nov 12, 2014 at 10:16 PM
    209taco
    209taco [OP] Member
    Sid
    Well so far i have about 1000 miles on the NGK iridium ix and they are not causing me any problems. i will report how they do and since no one had anything in stock with dual pole, i figured for 6.50 a peice it wasnt too bad.
  11. Nov 12, 2014 at 11:10 PM
    scocar
    scocar Patron of the Farts
    The service manual specifies 30k mile interval for non-platinum plugs.
  12. Nov 13, 2014 at 3:25 AM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    good old $2 a piece copper plug will run as good as any other, no need to pay $8 a piece for fancy plugs. On alot of newer motors that come factory with iridiums when searching for performance gains alot of times one of the first things recommended is to ditch the iridiums for basic copper plugs.
  13. Nov 13, 2014 at 5:46 PM
    OEM2011
    OEM2011 New Member
    I had the same experience, spark plugs were different on each side. NGK and Denso
