Spark Plugs & Wires for 2003 Tacoma 2.4L
Discussion in 'New Members' started by rickame, Aug 18, 2018.
  1. Aug 18, 2018 at 8:59 AM
    rickame
    rickame [OP] Member
    Rick
    2003 Tacoma 2.L standard cab
    New here...just looking for spark plugs and wires for a used taco I just picked up with 116k. Looking at NGK plugs, probably just standard copper or Vs (open to recommendations though) and can find these at many parts places. I'm having trouble/confusion finding wires. Local part stores like Auto Zone don't seem to list or handle wires for this truck, or maybe they are listed other ways. Online I do find a number of different NGK wires, like HE 53, HE 64, ZE 80, some of these listed for other honda/mazda/suburu but say they fit 2.L tacoma, some have 5th coil wire, some not. Are they all the same or what? Just need to know what to get, was assuming NGK makes wires for this truck too. Again, open to recommendations as to what and where to get. Thanks, newbie here...Rick
    PureTacoma likes this.
  2. Aug 18, 2018 at 9:11 AM
    BikerinBlak909
    BikerinBlak909 Well-Known Member
    SoCal
    96 LT 5 lug
    JD Fab LT kit 3" lift spindles Fox 2.5 x 10" dual rate Deaver F67 SUA, 9" shackles 8.4 prerunner rear end with 4.10 33 AT3 wildpeaks McNeil Fiberglass fenders PRP comp seats Doug Thorley long tube header K&N CAI
  3. Aug 18, 2018 at 9:26 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    Don't you have coil packs? That's probably why they don't list spark plug wires for 01-04 2RZ cause there are none.
  4. Aug 18, 2018 at 11:11 AM
    rickame
    rickame [OP] Member
    Rick
    Hmmm? One link to wires but many/which ones. Second note coil pack vs. plug wires..what is difference and what do I need (see initial thread?..2003 2.L Tacoma) Thanks for guidance.
  5. Aug 18, 2018 at 4:57 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW !!
    irayfz6 likes this.
  6. Aug 18, 2018 at 5:35 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Before wasting anymore time searching, pop your hood and look. If you have a 2003 2.4L you shouldn't have plug wires, you should have coil packs (black boxes on top of the spark plugs). 2000 & below has plug wires.
    Don't need to replace the coil packs unless you are having misfire issues or if maybe they are heavily corroded.
  7. Aug 19, 2018 at 8:33 PM
    rickame
    rickame [OP] Member
    Rick
    Thanks much...Yes I have coil packs, which I probably won't replace. But still not able to determine which of the NGK coil pack (with wire:) models is for the 2.4L.
  8. Aug 29, 2018 at 6:45 PM
    Dancing Weasel
    Dancing Weasel New Member
    Giuseppe
    2002 Tacoma Base Extended Cab
    Hi Rick,
    The original equipment part for the coil pack is
    Denso 673-1304 Ignition Coil and can be purchased from various sources for between $45 and $80 a pop.
    Unless you have a confirmed failure, these things are pretty bulletproof. My 2002 Tacoma with the same engine
    has 226K miles on it and has never required that particular part.
  9. Aug 30, 2018 at 4:39 AM
    rickame
    rickame [OP] Member
    Rick
    Thanks for the info. What I wanted to know, but as you suggest, not planning on changing, probably just plugs for now. Any suggestions on those?
    Since you have similar truck, ever have a problem with idle control valve, had a code, but really runs fine..takes about 30 secs to idle pretty smooth. Guidance always appreciated. Rick
  10. Aug 30, 2018 at 4:43 AM
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    2014 Black SR5 4x4 Access Cab
    Welcome to TacomaWorld to both of you!
  11. Aug 30, 2018 at 4:48 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2004 4x4 2.7L
    Denso K16RU-11 I believe is the part number for the plugs on the 2.4 and 2.7.
  12. Aug 30, 2018 at 4:53 AM
    Dancing Weasel
    Giuseppe
    Hi Rick,
    I bought a bunch of plugs over ten years ago and they are NGK BKR5EYA-11, Stock No. 2526. I am about to change the last set of them before a trip from TN to TX and back but in the future, I will probably go with the newer Iridium plugs, which are NGK 5464 BKR5EIX-11 Iridium IX Stock Number 5464.
    https://www.amazon.com/NGK-5464-BKR...=B003BUCKQ8&psc=1&refRID=2SS44042CQGWJXE55F33
    The plugs are supposed to be gapped at the factory (though I always check to be sure) and the newer NGK plugs supposedly do not require anti-sieze application. My Tacoma does run well but it has lost some of its power due to age. I fully expect to get 300K before spending tons of money on it other than routine
    maintenance. By the way, two of the plugs are easy to access but you need to remove the plumbing to the throttle body to access the other two, if my addled memory serves me well. Best of luck with your Tacoma.
  13. Aug 30, 2018 at 5:41 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW!
  14. Aug 30, 2018 at 12:36 PM
    PureTacoma
    PureTacoma www.PureTacoma.com
    Ray
    Texas
    '08 FJ Cruiser, '04 4Runner. '10 Tundra
    Welcome to the world my friend. Thanks for the hello.
