Spark plugs
Discussion in '1st Gen. Tacomas (1995-2004)' started by stucksucksnayota, Oct 12, 2010.
  1. Oct 12, 2010 at 10:00 AM
    stucksucksnayota
    stucksucksnayota [OP] Well-Known Member
    Barry
    Fort Smith, Arkansas
    14 Taco 4x4 TRD Sport DCSB
    OEM roof rack, Shorty antenna (eBay), soft tonneau cover, K&N drop in air filter, bed mat, interior LED lights, 5100's, MT tires to come soon!!!
    I have a few quick questions about the spark plugs in these trucks.
    1st does it matter if you run the double electrode type compared to the regular type?
    2nd is there anyway to gap the double electrode type plugs?
    3rd what is so special about the double electrode plugs? Better hotter spark?
    I plan on puttin in the NGK double electrode plugs but I just had a few questions that I couldnt find an answer too on here!
  2. Oct 12, 2010 at 10:09 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Yes you can gap the dual electrode plugs. Yes it makes a difference between running a single vs. dual electrode plug. AND, Use what the owners manual recomends. If your not SC'd, there is no need to run anything other than the OEM copper plugs.
  3. Oct 12, 2010 at 2:01 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Just more surface area for the spark to jump to.
    Just make sure you stay away from the bosch platinum plugs. They are trouble.
  4. Oct 12, 2010 at 4:35 PM
    kingston73
    kingston73 Well-Known Member
    eastern MA
    09 SR5 4.0L 4x4
    X's 2 on that, I tried the bosch when I first bought my truck and they were horrible, I've got standard NGK's in now and it runs well. I don't have the dual's though, would those give a noticable improvement over the single electrodes?
  5. Oct 12, 2010 at 4:47 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    I got mine from the dealer. Pretty cheap and I know they are the best for my engine.
  6. Oct 12, 2010 at 4:54 PM
    TacomaDan
    TacomaDan Don't go off ninjin
    Daniel
    Woodland, CA
    1996 Toyota Tacoma Fully Not Loaded
    Love, Cobra 29 LTD BT CB w/ A2000 Highgear antenna, FOX/Fabtech Coilovers, Magnaflow
    I dont know if you have the sticker or not but on the timing belt cover there is a sticker that says only use the dual electrode OEM type. PERIOD.
  7. Oct 12, 2010 at 5:02 PM
    TGurau
    TGurau Well-Known Member
    Tibi
    Portland, OR
    '98 SR5 4x4
    3" OME Suspension lift. PEX motoring headlights.
    I use the NGK iridiums and it does me good. A while ago, I had found out about seafoam and went overkill and put in 2 bottles in (i did half of one on a run, then the other half, then I went to the store bought another bottle and put in the whole thing). I did fine for a few hundred miles but once I tried to climb a relatively steep hill, my engine died. I had a huge problem with trying to start it and once I started it, it would die once i put it in gear. I managed to get it to a parking spot for the night. I went back the next day with a set of tools and took out my old spark plugs and they were really fowled. Coem to find out that the seafoam had broken down so much carbon from my intake manifold that it had fowled the spark plugs. I put in the NGK iridiums and they burned everything away like it was nothing. It was amazing to watch. NO JOKE! Iridiums are $10 a pop but so def worth it!
    Sorry for the long story :p
  8. Oct 12, 2010 at 5:10 PM
    magikbean562
    magikbean562 once flirted with danger, danger got clingy
    greg
    socal
    02 4runner 04 solara
    4runner-32x11.5x15 falken rocky mt, tundra king 2.5 coilovers with taco perch, TC UCA, OME rear springs and procomp es9000's, thule roof rack.
    i got my oem's from ebay on the cheap or you can get the ngk's from any local car parts store. i got some ngk's at home, i usually swap them out yearly. you can have them, just pay shipping :)
  9. Oct 12, 2010 at 5:17 PM
    TGurau
    Tibi
    Portland, OR
    '98 SR5 4x4
    NICE! What about the front turn signals? Did you replace the fog lights with those or did u put them somewhere else? It looks like you replaced the turn signals in the pic.
  10. Oct 12, 2010 at 5:25 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Well I would think some new stockers would have been fine once most of the carbon was gone. Not saying your wrong since I wasn't there but JMHO.
  11. Oct 12, 2010 at 5:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I agree.
  12. Oct 19, 2010 at 6:49 AM
    stucksucksnayota
    Barry
    Well I'm going to seafoam my truck tonight, but I only plan you use about half a can in the intake vac line so hopefully it won't foul my plugs to bad!
  13. Oct 19, 2010 at 9:48 AM
    vantaco
    vantaco Well-Known Member
    02 Taco Xtracab TRD Step Side
    newer run seafoam with plugs you plan on keeping...it kills them as the guy above noted
    best to do seafoam right before changing your plugs
  14. Oct 19, 2010 at 12:12 PM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    I just found out the previous owner was running single electrode plugs :eek: I been driving around with the wrong plugs in for almost 2 years...funny thing is there's been no hestitation while idleing or under load...
  15. Mar 19, 2012 at 2:04 PM
    tmt411
    tmt411 Active Member
    01 4X4 TRD
    K&N Filter system
    I have Bosch Platinum + 4 plugs in mine, if have heard mixed reviews on them do they suck if so why?
