Spark PLugs!
Discussion in '4 Cylinder' started by Noshownate, Apr 23, 2011.
  1. Apr 25, 2011 at 2:53 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    We have good members on this site, and everyone is just playin around. Any The link I posted shows the location of the plugs, and if you have any qurestions, please ask. :)
  2. Apr 26, 2011 at 7:11 PM
    Noshownate
    Noshownate [OP] Member
    Nate
    Florida
    2007 Toyota Tacoma Regular Cab
    I have thick skin, OH and to clear everything up I am a noobie to my truck maintenance soo alot of my posts will be noobieish.
    I dont even know what the coil packs are. i need to find a toyota tacoma 2007 service guide.
  3. Apr 26, 2011 at 7:11 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Check out
  4. Apr 26, 2011 at 7:20 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    I think someone needs to check up on this guy, so much can go wrong.
    OP...do one plug at a time, pull one wire, remove the plug, install correctly gapped OEM plug (no 12 tipped fusion induced plugs) snug down with a torque wrench (15-18 lbs, not sure which) or nothing larger then a 3/8" drive and replace the wire. After that move on to the next wire and plug. One at a time.
    Good luck and let us know when your done.
  5. Apr 26, 2011 at 7:34 PM
    That Dude Tim
    That Dude Tim Toyota Technician
    Elyria, OH
    11 TRD Sport 4x4 DCLB
    Falken Wildpeak AT3/W, BLK Mk6, ICON's, Firestone Ride Rites, SHLM, Rear view camera switch, 7-pin in bumper, Lighted 4x4 switch, ImMrYo bracket, mudflap delete
    Firstly pop hood
    then remove the plastic engine cover
    there you should see 4 black packs with a connector going to it (coilpack)
    remove the connector, (tip) use a small screwdriver to help push down the tab on the connector
    remove the 10mm bolt holding down the coil pack
    under the pack is the spark plug
    use an extension and spark plug socket to remove
    install in reverse order
    NOTE: these coil packs are NOT cylinder specific so no worries there, also don't over due it if you use antisieze on the new spark plugs
    PLUS if you buy dealer plugs they should be pre-gaped
  6. Apr 27, 2011 at 8:36 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    The OP is going into it with eyes open and very likely knows the potential downfalls of DIY maintenance. That is why he's on here asking questions... although I will admit that the original post "where are the plugs on my 4-cyl?" had me a little concerned. I'm just sayin', he's a big boy, let him have at it. With the support and advice of other TW users, there's nothing we can't do!
    OP, here are my tips: First, the procedure provided on this thread is good for the 1st and 2nd gen Tacoma 4-cyl engines, except the 2nd gen (2tr-fe) has coil-on-plugs and not wires like the pics show in that thread link. Do the plug change on a cold engine because the aluminum head is more easily damaged when hot. Definitely don't overdo the anti-seize, a little goes a long way but also make sure to use enough. I just smear it along one side of the threads and call it good, the threading action will spread it around. Torque the plugs to spec and stop there. And post pics of the used plugs for all to see, along with your mileage. Thx
  7. Apr 27, 2011 at 9:37 AM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    The plugs and coilpacks are covered by the intake silencer on the 2TR, which is a pain in the arse to remove the first time you do it.
    Completely loosen the two clamps on the intake pipe on either side of the silencer, one is on the connection to the air box, the other on the throttle body.
    Then remove the two little vacuum hoses on the front and right sides of the intake silencer. I think that there's also a little vacuum hose leading to the pressure sensor too, but I can't recall for sure.
    Then remove the larger ~1 inch diam. hose on the rear of the silencer (it's a PCV "overflow").
    Unclip the connector for the wires to the pressure sensor.
    Finally unscrew the 3 bolts holding the feet of the the intake silencer onto the valve cover
    Pull the intake pipe out of the rubber coupler on the air box side, then pull straight up on the entire intake silencer to get it off of the throttle body.
    One thing I did prior to changing the plugs was cover the throttle body with a plastic bag and rubber band since it's so close to where you're working. It would be easy to drop something in there on top of the throttle valve and not even notice.
    Follow everyone's advice on changing the plugs.
  8. Apr 27, 2011 at 5:19 PM
    ngrysen713
    ngrysen713 Member
    Nic
    Hudsonville, MI
    In Nate's defense, my seasoned-in-life grandfather had a hard time understanding that my plugs were where they were. Not everyone grew up watching their daddy service their own vehicles, and therefore had no inspiration to do it themselves either until they decided to delve into the task themselves (speak from experience). I commend the initiative, however, at the same time the search function on any forum can help immensely. Also, Nate, like another has said, pick up a Hayne's manual (or comparative book) on the vehicle, as it will last you awhile and be well worth the $25. If you want to save a few bucks, I found mine for my '97 on half.com for $12.00
    Good luck with your new truck!
  9. Apr 28, 2011 at 9:54 PM
    Noshownate
    Nate
    Florida
    sweet guys i appreciate the help very much!
    i will post pics and all sorts of maintenance i do custom and whatnpt on here it seem theyre are some knowledgable kind people here thanx.
    the shops around here want 40 dollars to do it. i think ill just have to buy the tools and i shoudl be good. thnx all.
