Spark Plugs?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RollTideJon, Aug 26, 2011.
  1. Aug 26, 2011 at 3:45 PM
    RollTideJon
    RollTideJon [OP] Member
    Jon
    Tennessee
    07 PreRunner TRD SR5
    none to date
    Has anyone used Autolite double platinums? If so, were they alright spark plugs or should i return and get the NGK V-Powers? Thanks
  2. Aug 26, 2011 at 4:02 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    Denso Part #K20HR-U11. These trucks don't need double platinum super coated anything plugs.
  3. Aug 26, 2011 at 4:21 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    Stick with stock. Anything else is a waste of money.
  4. Aug 26, 2011 at 4:54 PM
    fortyniner
    fortyniner Active Member
    Seattle
    08 tacoma 4x4
    I've got a 2008 with 23,000 miles on it and was wondering when I should start thinking about changing the plugs. It runs great with no starting or engine miss problems. It seems like with the individual coils and high secondary voltage the plugs would last a long time.
  5. Aug 26, 2011 at 4:56 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Dont worry about it until 30k miles
  6. Aug 29, 2011 at 6:31 AM
    RollTideJon
    Jon
    Tennessee
    none to date
    Thanks. That is greatly helpful. They didn't have the denso's in stock but i will be returning the autolites and having them order the denso's.
  7. Aug 29, 2011 at 6:33 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    good choice, i got like double platinum spark plugs cause they sounded like they were good when i was getting my oil from walmart... first time getting spark plugs. i went home and my step dad made me go return them and get ngks or densos.
    those are best for our engines as i have now learned:)
  8. Aug 29, 2011 at 7:22 AM
    textoy
    textoy Well-Known Member
    Fred
    Texas
    2011 4x4 TRD DC
    I used autolite platinums in my 99 LC for 60K miles on the 1st change. Also used them in my '04 Tundra. They were fine. I replaced them with iridiums in the land cruiser only because it is a PITA to change them in the cruiser and I wanted them to last longer. However, I could tell no difference in performance...and the autolites still looked good after 60k miles. At about $2.00 each at walmart vs $10.00 for the iridiums, there is no justification for the iridiums if they are easy to change.
  9. Aug 29, 2011 at 7:36 AM
    RollTideJon
    Jon
    Tennessee
    none to date
    So Denso vs. NGK, which is truly better? Or are they gonna be about the same? I know the NGK's cost a little more.
  10. Aug 29, 2011 at 10:41 AM
    bambooshoots
    bambooshoots Be a fountain, not a drain.
    Kevin
    College Station, TX
    2015 Honda Accord Sport
    I did it again. Got tired of paying truck payments and gas and traded in for a 2015 Honda Accord Sport since I enjoyed my 2013 Sport so much.
    This.
  11. Aug 29, 2011 at 10:46 AM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    My denso's were in better shape than the NGK's when I pulled mine out.
  12. Aug 29, 2011 at 10:53 AM
    Maticuno
    2011 Suburban 2500
  13. Aug 29, 2011 at 9:48 PM
    WATacoRider
    WATacoRider Well-Known Member
    TRD Sport 4x4
    I really should get my changed. I bought the truck at 37K miles 2 and a half years ago. Who knows if they were changed at 30K or not. :eek:
    Right now, I have 49K miles. Engine runs fine and I get the rated mileage on the freeway. 20.xxx MPG when it's 99.9% highway.
  14. Aug 29, 2011 at 9:49 PM
    georgeandkanoa
    georgeandkanoa the point is simply this
    jeff
    calgary
    07 tacoma trd
    bilstein5100's front tinted windows access cover pioneer stereo weathertechs grillcraft grill kc's behind cbi sliders
    what was the purpose of that anyway?
  15. Aug 29, 2011 at 9:51 PM
    toyotatacomaTRD
    I don't think anyone knows for sure. I am curious also.
  16. Aug 29, 2011 at 9:54 PM
    georgeandkanoa
    jeff
    calgary
    07 tacoma trd
  17. Aug 30, 2011 at 6:41 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Im not entirely sure. Some friends and I have discussed it at length, and the only thing we can think of, is the resistance values are slightly different from one side to the other, allowing them to run a cheaper plug on the driver side (NGK), thus saving a few pennys on each truck. Over the production run, this could be a very significant savings, but I cant verify any of this.
  18. Feb 2, 2012 at 11:08 PM
    pinktaco808
    pinktaco808 Hot Steppa
    #SK20R11
