Spark Plugs
Discussion in 'Performance and Tuning' started by socko3161, Nov 7, 2008.
  1. Nov 7, 2008 at 1:52 PM
    socko3161
    socko3161 [OP] Well-Known Member
    ok, So I just got my 40k oil change done at the dealership and they tried told me I should have my spark plugs replaced and that they recommend this to be done every 30k miles. Well seeing as though it is 10 over due, should I be worried about or are they just pulling my leg to get money... Also if I can just do it myself, anyone have any spark plugs to recommend me getting, I dont want the cheap 30 cent spark plugs from advance, any help would be much appreciated, thanks in advance
  2. Nov 7, 2008 at 2:16 PM
    MooseTX82
    MooseTX82 Moose
    San Diego
    08 TRD Sport 4x4
    Airaid Intake, Magnaflow Exh System, Icon Front Coilovers, TC UCAs, BFG 285s on 17" MotoMetal 951s, ARB Bumper, Hella Running Lights, Alpine CD HU, 6.5 Front JL Audio, 1 10" Kicker powered by Alpine 4 channel Amp
    I believe it is recommended to replace your spark plugs every 30K miles so I would say they are right. NGK seems to be a popular choice for most people.
  3. Nov 7, 2008 at 2:50 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    for the v6....plugs need to be changed every 30k. they are the standard copper core plugs. you can install a set of ngk or denso iridiums and they are good for 100k(they put them in the 4cyl from the factory)......but as easy as the plugs are to change.......i run the standard copper plugs and change them every 30k.
  4. Nov 7, 2008 at 3:31 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    yup. my 4 banger came with those iridium tipped suckers. nice to have em. but they are expensive to replace all at one time.
  5. Nov 7, 2008 at 4:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The Denso's are a better plug than the NGK. Its an easy swap. Take your time and remove everything in the way. Gap the plugs (I dont care if they say they are "already gapped", they arent). :)
  6. Nov 7, 2008 at 6:37 PM
    JCMINIS
    JCMINIS Well-Known Member
    Old fort NC
    07 sport,white 4x4,SR5
    Custom fr bumper,2.5 HBS front lift,rear TSB,K&N
    Anyone know the NGK number for the plugs ? Example my m/c uses BR8ES....
  7. Nov 10, 2008 at 4:06 PM
    ubermx5
    ubermx5 Well-Known Member
    Santa Clara CA
    98 2.4 5 speed
    K&N Air filter
    Denso and NGK both make great plugs.
    But you need to watch them both...
    Yes every 30K is a good number. if you are 10K over who cres, just get the right plugs and do it when you can.
    make sure to have Anti-sieze on the threads or you will damage the heads. that stuff is cheap.
    now plugs wires might go 60K. but get Factory type wires. they look better. or NGK..
  8. Dec 13, 2009 at 2:31 AM
    Flugelhornjazz
    Flugelhornjazz '06 4.0L 4x4 6-sp MT Access
    New England
    06' 4.0L 4x4 6sp MT Access
    AFE CAI, all synth fluids, 2.5" exhaust w/ FlowMaster, Optima Deep Cycle battery, Fog mod, SnugTop cap, HID headlights, silicone hoses
    I replace the plugs every 30K simply because everything else has been figured out. What I mean is remember when we worked on our cars in high school? Points, distributors, arcing wires, etc. I could get more HP to the rear wheels by replacing the point gap w/ a Mallory magnetic pick-up, better coil, etc. This '06 1GR motor has a coil for every plug and the ECM controls the timing. All of the "slop" has been designed out.
