Spark plugs
Discussion in '1st Gen. Tacomas (1995-2004)' started by Hektor, Dec 22, 2011.
  1. Dec 22, 2011 at 7:47 PM
    Hektor
    Hektor [OP] Well-Known Member
    Texas
    04 Tacoma 4x4 TRD DC v6
    Hi guys Ill be changing thr spark plugs in a couple of weeks on my 2003 Tacoma V6 Ill be using oem spark plugs. My question is should I change the cables or coil packs as well or wait till it hits 90k to change the wires?? My truck has 61k at them moment so I dnt know if I should just to the spark plugs only. What do you all recommend me. Thanks in advance
  2. Dec 22, 2011 at 7:56 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    I'm still running the original wires and coil packs. I'm at ~114K.
  3. Dec 22, 2011 at 9:00 PM
    Hektor
    Texas
    So no need to change them yet huh
  4. Dec 22, 2011 at 9:16 PM
    Digiratus
    Roaming the PNW
    The RedHead
    If it was me, I'd just do the plugs and see what you get.
  5. Dec 22, 2011 at 9:26 PM
    Hektor
    Texas
    I think thats what Im gonna do. Like I said my truck has only 61k and is running great, but I know I need to change the plugs every 30k
  6. Dec 27, 2011 at 3:21 PM
    Tbones taco
    Tbones taco Well-Known Member
    Tony
    Carrollton
    07 PreRunner ext cab
    Flowmaster 40 smittybuilt bull bar smittybuilt nerf bars hella lights crome custome grill
    Just changed mine. I bought it used and they were never changed by previous owner. i changed them at 82k and what a diffrence it made. the driver side had NGK and the other was Denso. both were around .60 when they should be .40-.41. the NGK looked burned (lean) and the Denso looked good. I put all OEM Denso's in and she runs great. I didnt change any coil packs but i did clean the off and used dilithium grease on the gaskets.
  7. Dec 27, 2011 at 3:29 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    Here are mine after 115k miles. I changed them this past Friday and it made a world of difference I had a slight knock/rattle sound which I suspected to be the plugs, and now they are gone. The truck runs way smoother and starts easier now. I replaced them with OEM NKG because they seemed to fair the best between the Denso's and NKG's. I didn't change the coil packs or wires just the plugs and put some anti-seize on the threads and dielectric grease in the boots. She's running like a champ now.
  8. Dec 27, 2011 at 4:57 PM
    Tacomadude89
    Tacomadude89 Well-Known Member
    Austen
    California
    2002 Tacoma TRD SR5, 3.4, 5spd
    -Bilstein 5100 Series shocks on all 4 corners -Rancho HD lift coils -1/4" Toytec driverside top plate spacer -Toytec 1" diff drop -Wheelers 1.5" AAL's -Toytec 1" lift shackles -Revtek extended length BPV bracket -285/75/16 BFG KO T/A's -Pro Comp rims -ET Conical tyle lug nuts -Spidertrax 1.5" wheel Spacers -CV Boot slide mod -TRD skid plate -Magnaflow 14" round muffler -Shortened tailpipe hidden behind framerail -Toyota bug deflector -Weathertech floormats -Black leather seat covers -Valentine 1 Radar Detector
    Yeah, just do the plugs for now. For a first gen, that's low mileage.
