Spark Plugs
Discussion in '4 Cylinder' started by Mike.B, Dec 23, 2008.
  1. Dec 23, 2008 at 7:29 PM
    Mike.B
    Mike.B [OP] Member
    i have a 2005 2.7, and was wondering what is the best spark plug i can put in my truck. thanks for any input.
  2. Dec 23, 2008 at 7:43 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Use the OEM plugs.
  3. Dec 24, 2008 at 9:31 AM
    106Tacoma
    106Tacoma Well-Known Member
    Debadged 06 Black Sand Pearl 4x4 Every option.
    I just orderd densos, the oem ones are around 3 dollars each, these ones where almost 21 dollars each but have a 100,000 mile lifspan. Good ill never have to change them again haha. What does everyone else run? These are platinum iridiums.
  4. Dec 24, 2008 at 9:33 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The platinum iridiums are not recomended, and a few people have had deteriorating performance when useing this type of plug. Best performance in the 1GR-FE is with OEM nickle plugs.
  5. Dec 24, 2008 at 9:34 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Check the gap on those plugs @ 30,000 miles, and you will be supprised.
  6. Dec 24, 2008 at 9:38 AM
    106Tacoma
    Well im going to try them and see for myself, so far my truck has had a mind of its own on almost every issue.
  7. Dec 24, 2008 at 7:05 PM
    Mike.B
    Mike.B [OP] Member
    looks like ill be getting OEM, i thought i would be doing a good thing by getting $15+ a peice spark plugs. thanks for the input
  8. Dec 24, 2008 at 8:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The 2.7 does use iridium plugs, so depending on what you are looking at, it may be what the truck is designed for.
  9. Dec 24, 2008 at 9:20 PM
    PwRTRIp_Xr
    PwRTRIp_Xr Active Member
    Denso iridiums bro, dont buy ngk brand those are crap make sure its denso bro......
  10. Dec 24, 2008 at 9:49 PM
    scottc
    scottc Well-Known Member
    Raleigh NC
    2019 TRD Sport 4X4
    KDMAX- Pro Tune TRD Exhaust
    How often should you change the plugs on the new 2.7?
  11. Dec 25, 2008 at 12:13 AM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    What does your owner's manual say???
  12. Dec 25, 2008 at 6:22 AM
    106Tacoma
    fr the 4.- it says 30k, but thats for the facotry cheapo densos.
  13. Dec 25, 2008 at 6:51 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No. The 2.7 uses Iridium plugs and the interval is 100,000 miles. The 4.0 v6 yses Nickel Benso (which is a good plug) and NGK (which is so so).
    The factory uses plugs with the propper resistance and designed for optimum performance with its ingnition system. Many times, throwing in a different plug, i.e., an platinum plug when an Nickel plug is called for, give less performance because the platinum plug runs at a different resistance. Now days, ignition systems arent like the old distributer and capacitor therefore a better plug yeilds better performance. Everything is electronically controlled, and engineered to work as well together as possible. Just use what the owners manual says, and you will be fine.
  14. Dec 25, 2008 at 6:56 AM
    scottc
    Raleigh NC
    2019 TRD Sport 4X4
    Thanks, I was thinking it was 100k for the 2.7.:thumbsup:
  15. Dec 29, 2008 at 10:58 PM
    dthiss21
    dthiss21 DTHISS
    Missoula
    02 Tacoma extened cab
    Deckplate mod, Grey Wire mod, 3" strut spacer lift, 6 100watt lights, reverse lights,
    you guys are on crack.. CHANGE YOUR PLUGS ONCE A YEAR!!!! Its cheap and doesnt hurt anything..
  16. Dec 29, 2008 at 11:04 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    ^ Why change them out if they're still good? Why not just follow the manual and change them out when they need to be changed out? I suppose you think you know more than the Toyota engineers?
  17. Jan 2, 2009 at 1:26 AM
    dthiss21
    dthiss21 DTHISS
    Missoula
    no i dont, I"m just a poor kid working at a NAPA lol.. but do you really think a 3$ spark plug can really last 60,000 miles at PEAK performance???. I bet you an NGK can deffently last that long.. But will it still be performing as it did new? From personal experience I've found having newer plugs have kept me from losing one. If i'm going on a road trip I would rather have plugs with 5,000 miles on them and not 55,000...
    Whats the BEST plug for a 02 3.4L??? just standard OEM? or has anyone tried the V powers or anything??
    thanks dan.
  18. Jan 2, 2009 at 6:20 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    From everything I have heard/done, the OEM twin ground Densos are the best. People have had poor performance when useing other plugs. Also, no matter what the box says, be sure to gap the plugs @ .040.
  19. Jan 2, 2009 at 8:43 AM
    humanoid
    humanoid bite me
    Sunny SoCal
    Standard OEM plugs were meant to be changed out at every 30K miles (at least for the 5vz-fe I had), not sure where you got your 60K mile figure from.
  20. Oct 21, 2009 at 11:55 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Sorry to resurrect such an old thread but I was wondering about the spark plugs in my 06 2.7L. The OEM documentation recommends changing the spark plugs at 120k.
