Spark plugs ?????
Discussion in 'Performance and Tuning' started by crazed, May 21, 2013.
  1. May 21, 2013 at 8:56 PM
    crazed
    crazed [OP] Active Member
    Carl
    Missouri
    03 Tacoma DC, SR5, TRD
    Has anybody tried those Bosch 4 electrode iridium plugs in their v6? Think they might work as well as the OEM Denso plugs?
  2. May 21, 2013 at 9:04 PM
    TrdSurgie
    TrdSurgie revised
    SoCal
    No. No. No. No. No.
    Just use the denson. Welcome to TW
  3. May 21, 2013 at 9:16 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    +1
    Lots of snake oil being disguised as spark plugs.
    Multiple-electrode (actually shrouds the spark), gaps built into the insulator to make the spark "hotter" (at the expense of your coil).
    The engine is equipped with the best plugs to make it run.
    Copper for the 4.0 every 30k, Iridium for the 2.7 every 100k.
  4. May 21, 2013 at 10:32 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Ya can't beat factory plugs..... Plain, simple, and gets the job done.
  5. May 22, 2013 at 8:41 AM
    colby8100
    colby8100 Well-Known Member
    Colby
    South carolin
    01 Tacoma 1jz lowered
    Lowered,leather interior,system,1jz swap,rims,painted bumpers mirrors ect
    Toyota runs a ngk dual ground iridium plug in newer boosted engines. I spent 4 months trying to find them in the us but Toyota bought the patent for them and they were 14 $ each when I bought them from toyota. made a big difference at high boost. But my ignition was designed by Toyota for them
  6. May 22, 2013 at 6:58 PM
    hantavirus
    hantavirus New Member
    Bakersfield
    '95 Xtra Cab
    While this is my first Tacoma, I have had several vehicles, and I have always performed the majority of the maintenance. My personal experience, especially with imports, is that you are usually better off sticking to the manufacturer's recommended plug. Some expensive plugs may end up giving you big disappointment.
    Example: My truck didn't idle well with the a/c off when I purchased it. I removed the Autolite spark plugs and replaced them with NGKs; Problem solved, the truck now idles just fine, and runs better as well.
