Spark plugs
Discussion in 'Performance and Tuning' started by turbotime, Jul 22, 2014.
  1. Jul 22, 2014 at 6:41 PM
    turbotime
    turbotime [OP] Member
  2. Jul 22, 2014 at 6:52 PM
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    Go with the denso's. If you can't then NGK would be the next best thing. After reading so much on the subject of spark plugs I've heard good things about both denso and NGK but oem denso's seem to be the best choice.
  3. Jul 22, 2014 at 6:53 PM
    turbotime
    thank you
  4. Jul 23, 2014 at 2:03 AM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Im running denso with no issues
  5. Jul 23, 2014 at 9:34 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  6. Jul 23, 2014 at 9:39 AM
    lawless
    lawless the rent is too damn high
    Lawson
    San Jose, CA
    2012 dcsb mgm sc
    perhaps a poll: Denso vs. NGK?
    it would be curious to see how TW folks are sparking up.
  7. Jul 23, 2014 at 9:53 AM
    TRDrunner
    TRDrunner Well-Known Member
    Victor
    Vacaville
    2014 Tacoma TRD Offroad
    Tacoma from factory run densos on one side and ngk on the other due to the fact that the heads are manufactured in 2 different plants. Id go with factory Densos. Imo
