Spark plugs
Discussion in 'Technical Chat' started by rab89, Dec 20, 2009.
  1. Dec 20, 2009 at 10:30 PM
    rab89
    rab89 [OP] Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    When's the last time you changed your spark plugs? i hadn't ever done mine, as I've only had my truck for a year and a half. but I was at the store today, and picked up some bosch platinum plus plugs, on sale for 3 bucks a piece.
    It only took about an hour.
    my truck had a hesitation, it felt like a turbo was kicking in cause it wasn't getting much power in the lower rpm's. well that went away, and my throttle response seems a bit better too! AWESOME! My mpg has been shitty lately too, so hopefully this helps.
    I'd recommend you do it if you haven't in a while.
  2. Dec 20, 2009 at 10:50 PM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    Yeah I agree, new plugs can make a big difference... but why'd you get the platinum ones? Should have gone with Iridium plugs then you wouldn't have to change them so often..
    Iridium Spark Plugs:
    Iridium spark plugs, which are available for select Toyota models, have several benefits:
    A smaller center electrode and promoting higher performance.
    Iridium is a more durable material than platinum (its melting point is approximately 1,200° F higher than platinum).
    And Iridium spark plugs last longer than conventional spark plugs. (Up to 110,000 miles.)
    http://www.toyota.com/dealers/services/spark_plugs.html
  3. Dec 20, 2009 at 11:08 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    because I kept putting it off and i didnt do my research ahead of time :p
    I don't mind doing them more often though, pretty cheap and easy. but thanks for teh heads up, I'll try them next time
  4. Dec 20, 2009 at 11:18 PM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    I changed mine @ 80,000 miles to Irridium plugs.
