spark plugs
Discussion in '1st Gen. Tacomas (1995-2004)' started by Hambone155, Jan 1, 2010.
  1. Jan 1, 2010 at 8:56 AM
    Hambone155
    Hambone155 [OP] Well-Known Member
    omaha
    Causing Butthurt is my job
    port and polish intake manifold, supercharger, pulley for charger, lifted, tires, deckplate, (doing full engine build)
    what is the best one to buy for the tacoma?
  2. Jan 1, 2010 at 8:59 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    OEM twin ground plugs for the 3.4
  3. Jan 1, 2010 at 9:38 AM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    ^^^Yep! Yep! the Denso plugs.
  4. Jan 1, 2010 at 3:49 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Denso or NGK, but make sure to get the twin electrodes or your 5vz-fe will run like crap.
  5. Jan 1, 2010 at 3:55 PM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    Not only that, but the timing cover says to use the dual ground plugs. :cool:
  6. Jan 1, 2010 at 4:00 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    Isn't that what I said? :confused:
  7. Jan 1, 2010 at 4:03 PM
    Afwrestler1986
    Johnstown, NY
    Yes that is exactly what you said, I was emphasizing that on the timing cover it plainly states dual ground plugs are to be used. Just pointing that out.
  8. Jan 1, 2010 at 4:06 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    Gotcha! :thumbsup:
  9. Jan 1, 2010 at 6:10 PM
    Beau02
    Beau02 Black Taco
    Beau
    Indianapolis, IN
    2002 4x4 Limited TRD V6 Auto (190k+, 1-owner)
    Lots of small stuff; Grillcraft MX, Bilstein 5100's, Deck Plate Mod w/ K&N air filter, Airaid MIT, braided SS brake lines, Redline Tuning QuickLIFT hood struts, Extang Full-Tilt tonneau cover, fog light mod, gray wire mod, power outlets on-demand, Diff breather ext, additional contours to passenger side from oak tree.
    I was a dumbass and (prior to joining this forum) replaced mine with NGK Iridiums and lost about 2 mpg...
  10. Jan 2, 2010 at 3:27 AM
    ScottyB
    ScottyB Well-Known Member
    Scott
    Kailua, Hawaii
    01 PreRunner TRD V6
    Bilstein 5100's
    Is there something that makes the Denso dual ground plugs different from other multi electrode plugs?
    edit: and by different I don't mean like "Denso is better because its oem!" but different in some technical way. I hear these plugs mentioned alot regarding Toyotas so I'm wondering if they have some magic built into them :p
  11. Jan 2, 2010 at 3:30 AM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
    I just replaced mine with bosch platinum, they are single prong, is it that bad? or am I ok for a bit?
  12. Jan 2, 2010 at 7:11 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    They are the correct heat range, and resistance required by the Ignition.
    Thats a cooler plug. You "could" have carbon buildup on the tip, and possible a CEL.
  13. Jan 2, 2010 at 7:22 AM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    Stick with OEM plugs...I tried the "NGK Iridium Sure Fires" for shits and can't tell the difference :cool:
  14. Jan 2, 2010 at 9:48 PM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    i just looked at my old ones, they are twin electrode, but NGK, I've gona about 1000miles with no CEL...
  15. Jan 2, 2010 at 9:55 PM
    blegros
    blegros Member
    I've seen people run Bosch fine until they melt their coil
