SPC 2 1/2* and 3* rear leaf slotted axle shims
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by Fox2011PM, Jan 5, 2019.
  1. Jan 5, 2019 at 2:55 PM
    Fox2011PM
    Fox2011PM [OP] "The Mountains are calling"
    '13 DCSB 4X4 TRD OR
    ADS 2.5" CO's w/adj, ADS 2.5" Rears w/ piggybacks, Firestone air bags and 1.5" AAL, SCS SR8s, Tom Woods custom one piece drive shaft....more to come
    image.jpg image.jpg image.jpg image.jpg Slotted axle shims that, once installed with the extended leaf pins (by means of a pin head extension), can be removed or installed by simply unbolting u bolts and separating leafs from axle perch. 3 degrees were used for approx. 30k miles, and 2 1/2 degree shims have never been used. Ordered from Headstrong. Buyer will need the leaf pack pin head length extenders. These can be purchased from Headstrong for $10 a pair. I'm asking $15 shipped for either set or $25 shipped for both sets
  2. Jan 6, 2019 at 8:42 AM
    Thyces
    Thyces 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    I'll take both
  3. Jan 6, 2019 at 1:10 PM
    Fox2011PM
    '13 DCSB 4X4 TRD OR
    PM sent
