SPC adjustable UCA help please.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dutchcontractor, May 12, 2021.
  1. May 12, 2021 at 6:42 PM
    dutchcontractor
    dutchcontractor [OP] Well-Known Member
    Going to install SPC UCAs this weekend and was hoping to not need an alignment right away, because life...
    Instructions tell me what setting to use to keep factory caster, but what about camber? I have factory UCAs right now with a decent alignment.
    Anybody have experience with this?
  2. May 12, 2021 at 6:54 PM
    Shavenyak
    Shavenyak Active Member
    Roman
    2021 Army Green TRD Offroad
  3. May 12, 2021 at 7:07 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    I've installed a few SPC's. Camber must be set manually. The adjustment bolt should be set outward almost all the way. Instructions say to start at the center, but so far that has resulted in lots of negative camber.
    After making camber adjustments, need to take the truck for a short drive. Either down the block, around the block, or up and down the driveway a few times. Then come back and check camber again. This allows the suspension to settle.
    You will need a toe alignment as well. The longer the alignment is out, the faster your tires will be wearing at an accelerated rate.
  4. May 15, 2021 at 12:34 PM
    dutchcontractor
    Just completed the install. That was much easier than expected. Used the device that @Shavenyak suggested and your alignment advice.
    Toe was out quite a bit after install. Was an inch difference between the front and the back of the wheels.
    I feel confident that I got the alignment pretty good, so I can schedule a proper alignment within a few weeks.
  5. May 15, 2021 at 12:38 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Would a chalk test help confirm your confidence?
  6. May 15, 2021 at 12:51 PM
    dutchcontractor
    That would be a good idea regardless. Still need to figure out what the proper pressure is for these tires anyways.
    Skydvrr[QUOTED] likes this.
  7. May 28, 2021 at 3:22 PM
    dutchcontractor
    Ha! Just got it back from the shop today. I was only off 0.06 degrees on the driver side toe, rest was pretty much spot on!
    Caster is at 4.
    Not bad for a driveway alignment.
    Shavenyak and Big tall dave like this.
  8. May 28, 2021 at 3:53 PM
    YotaJoe
    YotaJoe ig @_yotajoe
    Darren
    Vegas
    2017 Tacoma TRDsport 4x4
    insta@_yotajoe : 5100s / spc uca, 34' cooper mts, allpro sliders/skids. sherpa roof rack. agency6 goodies, BAMF hybrid front bumper, BD lights/Hella spots.
    impressive, good info in this thread. I have spc's and once I go up to 35s will need to do some adjusting myself.
