Spc ball joints
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MauiJR808, Nov 3, 2021.
  1. Nov 5, 2021 at 6:31 PM
    #41
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Moving that balljoint all the way out from where it is will make a big change in your camber.
    What do you LCA cams look like?
  2. Nov 5, 2021 at 6:34 PM
    #42
    TacoPharm
    TacoPharm Follower of Jibbers Crabst
    Phil
    San Diego
    MGM 2017 Tacoma TRD Off Road 4x4
    SPC Light Racing UCA Eibach Pro-Truck Lift System Deaver Stage 1 Leafs Wheelers Superbumps x4 Wheelers U-bolt Flip Kit SCS Ray10 16x8 Gun Metal 285/75/r16 BFG A/T KO2 CMC by @Speed Freek 4.88 Gears CBI Alu Full Skids Sliders by @Shmellmopwho SOS Concepts Streamline Bumper Warn Xeon 10-S winch Factor 55 Flatlink E recovery shackle Optima Red Top 35 @Coupe “TRD” Batt. Hold down Baja Designs Squadron SAE Fogs Caliraised Ditch lights Hypertech Speedometer corrector Fend-X inner fender guards ARE Z-Series Topper DYI sleeping platform
    Then get an alignment ASAP?!? You might not want to drive very far after setting your ball joints to the D position and in the outer most position.
  3. Nov 5, 2021 at 6:40 PM
    #43
    mauctopa
    mauctopa Well-Known Member
    Put you coilovers close to stock height and reinstall the sway bar with 1 inch spacer blocks under
  4. Nov 5, 2021 at 6:56 PM
    #44
    MauiJR808
    MauiJR808 [OP] Well-Known Member
    Jrey
    Hawaii
    2008 black tacoma 4x4
    Paint black with gold pearl with camper
    So I told my local alignment shop to move my wheels forward so that I have better clearance on my cab mount. I also did a cab mount chop. Not sure what my LCA is set. I'm thinking if I do put my ball joints on D and slide it forward. I need to drive it straight an alignment shop.
    TacoPharm and bassbrick like this.
