Spc control arm questions
Discussion in 'Suspension' started by 98tacojunky, Nov 29, 2019.
  1. Nov 29, 2019 at 8:29 AM
    98tacojunky
    98tacojunky [OP] Well-Known Member
    Upstate NY
    2019 TRDOR double cab
    I have a few questions regarding a set of used spc control arms I picked up a little while ago.
    1. What version are these? I assume they are a very early design. Does this design have any issues?
    2. camber adjustment once in, from my understanding the arms allow for +- 2 degrees of camber. If I leave them in the middle of the adjustment, would that keep my camber pretty close to what it is currently?
    3. I’m currently on a 6” bds lift and my caster is around 2-2.5, if I set the spc’s to the f position that would add .25 caster is there any Reason this can’t work? What is the whole ball joint setting Measurement they talk about?
  2. Nov 29, 2019 at 8:31 AM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    There's an entire thread dedicated to SPC arms. Wish I could find the link, you'll have to use the search feature.
    98tacojunky[OP] likes this.
