SPC Disappointment - Need Budget Friendly UCA
Discussion in '2nd Gen. Tacomas (2005-2015)' started by spazjensen, Apr 23, 2025.
  1. Apr 23, 2025 at 8:34 AM
    spazjensen
    spazjensen [OP] Well-Known Member
    Here
    06 Tacoma Prerunner SR5 4cyl 5spd Manual
    3" lift with Biltein 5100's w/Eibach Coils, SPC UCAs
    I guess I can be added to statistics of having the SPC controls arms yielding problems. I've had a harsh clunking noise I've been tracking down last few months. Replaced a LBJ (was needed), did the "zip-tie mod" on the rag joint in the steering column, and pushed, pried, pulled at every movable part on front suspension and steering.....and then I tugged at the UCA.....CLUNK CLUNK
    First thought was the SPC ball joint, no movement there, greased it heavily, no improvement. Noticed I could feel the clunk in my hand the closer it got the bushing...sure enough I can feel it shifting with every push and pull on the UCA. Replacement bushing kit is $275+ and then the headache of replacing them.
    In all my troubleshooting these were the last thing I suspected because they are the newest parts on the whole truck. Surely it couldn't be the 'new' UCA I installed and barely used, but here I am now. I installed these in 2021, I put maybe 25K miles on the truck since then. Very disappointed when I called SPC's customer service and was told this was out of warranty.
    Looking for options for replacing the UCAs all together because I'm not dealing with SPC anymore after this. I followed the directions and then some extra care just to insure I didn't botch the install and mess the bushings up in the process. I've read up some on JBA UCAs, but would like/need more insight before committing.
  2. Apr 23, 2025 at 8:48 AM
    hinmo24t
    hinmo24t MAhole
    tom
    dartmouth, ma
    2015 TRD OR , blue ribbon metallic
    oem. ran them for 7.5 years with 5100/ome spring lift 2"
    going to do the same soon with my full old man emu heavy kit, oem UCA
  3. Apr 23, 2025 at 8:52 AM
    spazjensen
    Here
    I did the same after I lifted mine. Ran the OEM's through two sets of tires, but I had alignment issues and tire was rubbing the UCA occasionally. Was why I replaced them.
  4. Apr 23, 2025 at 9:08 AM
    hinmo24t
    hinmo24t MAhole
    tom
    dartmouth, ma
    RIGHT ON
    interesting too. i only ran 255 75 75 pizza cutter on fj cruiser wheels for the t4r setup i had, 2004
    now my 2015 itll be 255 75 17 again, and 0 offset 17x8, old man emu 2.5
    hoping to run the stock uca again...
    old man emu sells UCA, and IRONMAN i think too, and big ironman sale going on right now, 25% sitewide, good luck
  5. Apr 23, 2025 at 9:11 AM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    The X axis bushings are junk.
    The old style Spec bushings are way better but they no longer sell them for some stupid reason.
    I have 100k+ miles on my set and they’re still solid.
    I dread the day I have to replace them.
  6. Apr 23, 2025 at 9:16 AM
    HWI
    HWI Well-Known Member
    North Florida
    2015 Tacoma TRD Off Road
    You can get OME UCAs for a pretty reasonable price compared to other quality aftermarket UCAs. They've held up without issue for me.
    hinmo24t likes this.
  7. Apr 23, 2025 at 9:22 AM
    DoubleB
    DoubleB Well-Known Member
    Bakersfield CA
    22 TRD Pro / 06 PreRunner
    My son has been running the budget Freedom OffRoad UCAs on his 2000 Tundra for about 2 years now with a 2 1/2 lift. Now issues so far.
  8. Apr 23, 2025 at 9:41 AM
    spazjensen
    Here
    The Freedom set look appealing to my budget. Similar to OEM setup, but with the alignment correction for the lift. And servicable.
  9. Apr 23, 2025 at 9:42 AM
    spazjensen
    Here
    yeah i am not happy with SPC right now.
  10. Apr 23, 2025 at 9:46 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Ironman used to be rebranded OME. Who knows what they are now.
    Get Total Chaos. They are rebuildable too
