SPC LIGHT RACING UCA'S
Discussion in 'Product Reviews' started by brutalguyracing, May 18, 2013.
  1. Jul 31, 2014 at 8:33 AM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    x2 (two years). Love the Alignment options.
    While some mechanics don't quite get around the idea thata: the UCA is adjustable and b: I wanted my alignment out of specs but whenthey learned how to adjust the top, alignments got very easy.
    The Toyota mech figured itout quick. The Firestone mech is a bit slower on the uptake...
    I wanted toincrease wheel clearance. The mech just about maxed out the lower Camber (brought the lowerball joint out but kept some room for adjustments) and just about maxed thelower Caster (brought the lower ball joint forward, again, keeping room foradjustment), then adjusted the top ball joint for ~3* caster and 0* camber.Ultimately this brought the entire tire forward and out. I got lucky and hadJUST enough UCA camber adjustment to keep the lower tab maxed.
    After the initialalignment, instead of messing with the lower arm tabs (when you adjust one, youhave to adjust the other - its a PITA) the mech just has to do a minor Casteradjustment on the lower and fix the Camber form the top. Takes ~30 from startto finish. I haven't adjusted lower camber for over a year and he recomended loosening the adjustment bolt every two visits to keep it from seizing.
    I also torque the UCA boltto 150 ft/lbs. I called the technical officer at SPC and the tech verified thebolt was good for up to 190-200 ft/lbs but recommended no more than 150-170.
  2. Jul 31, 2014 at 8:43 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    you never go 4 wheeling and how many miles can you put on a truck in 4 years when on a island?
    Ive seen two failures in person.
  3. Jul 31, 2014 at 8:49 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    If you mean rock crawling that's true , if you mean fire roads like I see in your wheeling pics , I do that
    I have about 55 000 miles on my truck and I didn't say you hadn't seen any failures , I was just stating my experience with them
  4. Jul 31, 2014 at 8:57 AM
    XXXX
    sKiP
    05 Prius
    I haven't posted wheeling pics of my Tacoma in quite some time and they were not fire roads when I did. You must be getting mixed up with my 18 year old Ford Explorer that I drive on the fire roads.
    As am I.
  5. Jul 31, 2014 at 9:04 AM
    XXXX
    sKiP
    05 Prius
    I have never seen Total Chaos redesign, recall, or replace parts for free (except for the change to stainless balls). They are expensive because they do proper R&D.
    If you want it done right the first time and you want it to last when beaten TC all the way.
    Ive seen OP's POS SPC arms many times and they are nothing but a pile of crap. Every other month it was something new failing, clicking, or falling apart. They used their customers as R&D thus the redesign.
  6. Jul 31, 2014 at 9:12 AM
    OZ-T
    Peter North
    British Columbia
    TC makes adjustable UCA's ?
  7. Jul 31, 2014 at 10:15 AM
    XXXX
    sKiP
    05 Prius
    You are clueless hu?
    Mine can be adjusted from 2.5* all the way up to 3.8*.
    Jlink just installed his 36's and now has 3.8* and he was previously at 3.0*. I'm at 2.5 or 2.8 I think.
    Just because they have no adjustment doesn't mean they can not be adjusted with the truck to work perfectly OK. Most times they are easier to adjust because the retard doing the work doesn't have the option to install the POS adjustment blocks backwards :cool:
    SPC sucks / story
  8. Jul 31, 2014 at 10:18 AM
    OZ-T
    Peter North
    British Columbia
    No not clueless , I was asking if TC made an adjustable UCA , I know how an alignment works , thanks for the tampon response as usual though
  9. Jul 31, 2014 at 10:57 AM
    XXXX
    sKiP
    05 Prius
    You know TC doesn't make them adjustable so stop being a bating douchebag as usual.
  10. Jul 31, 2014 at 11:07 AM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
  11. Jul 31, 2014 at 11:14 AM
    XXXX
    sKiP
    05 Prius
    thats not butter
    I just pissed in your popcorn while you were looking the other way:D.
  12. Jul 31, 2014 at 11:17 AM
    OZ-T
    Peter North
    British Columbia
    Actually I didn't know if they made a ball joint style UCA or not
    Now I guess I do , thanks Captain Menstrual
  13. Jul 31, 2014 at 11:18 AM
    NC15TRD
    Nick
    PA
    Damn lol
  14. Jul 31, 2014 at 11:22 AM
    XXXX
    sKiP
    05 Prius
    Well then I apologize. I thought you were asking retarded sarcastic questions to bait me like you seem to like to do.
    Looks like the BC meets will be over now :( Sucks I missed the last one.
    You coming camping in September?
  15. Jul 31, 2014 at 11:24 AM
    #35
    NC15TRD
    Nick
    PA
    I hope they aren't! That's where I've met everyone from the site!
    OH HELL YES! I already got approved for vacation for it!
  16. Jul 31, 2014 at 11:33 AM
    #36
    XXXX
    sKiP
    05 Prius
    Sweet! My buddy just sent me a text wondering what was going on. We need to start planning sooner than later since it's coming up.
  17. Jul 31, 2014 at 12:04 PM
    #37
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    I disagree. Customer service is good and so far the (1st gen) product is good :notsure:.
    I dont see the need for a uniball (and the $$$ associated with it) unless you are running LT.
  18. Jul 31, 2014 at 12:12 PM
    #38
    OZ-T
    Peter North
    British Columbia
    Like I said earlier , no issues with mine in 4 years
  19. Jul 31, 2014 at 12:24 PM
    #39
    XXXX
    sKiP
    05 Prius
    sorry I didn't know I needed to be that specific because this is a review for 2nd gen SPC arms :rolleyes:
    troll on trollmaster
  20. Jul 31, 2014 at 12:28 PM
    #40
    OZ-T
    Peter North
    British Columbia
    Scott was not exactly the most gentle person on his truck no ?
    So him having premature issues with wear parts doesn't exactly suprise me .
    Who do you know that had broken welds on the arms ? Was that Scott too ?
