SPC UCA Bad ball joints after 20k
Discussion in 'Suspension' started by CMillTacoma, May 23, 2022.
  1. Jan 2, 2024 at 7:05 PM
    #61
    Bishop84
    Bishop84 Well-Known Member
  2. Jan 2, 2024 at 7:07 PM
    #62
    Bishop84
    3JOH22A likes this.
  3. Jan 4, 2024 at 3:29 PM
    #63
    CMillTacoma
    CMillTacoma [OP] Well-Known Member
    Craig
    Colorado
    2025 TRD OR Hybrid
    Toyota recommends 10k.
  4. Apr 16, 2024 at 6:46 AM
    #64
    Stagger Lee
    Stagger Lee Well-Known Member
    NorCal
    2015 Tacoma TRD OR 4x4 6spd
    My passenger side has been making a ton of noise. Crawled underneath and looks like the boot has failed and there’s grease everywhere. Bummer. I’ve only had them about 20k.
    I called SPC and the guy said there is a new design that is self-contained with no zerk fitting. He said they no longer make the zerk models. Part 25001.
    I went ahead and ordered them from JEGS. Going to replace them both when they get here then have it realigned.
    Has anyone else bought the newer style ball joints without the zerk fitting?
    https://www.jegs.com/i/Specialty+Pr...IFCUH-OxjqCCP7cJ8p_AZHyKDdsN3aWRoC0XoQAvD_BwE
  5. Apr 19, 2024 at 9:34 AM
    #65
    908tacoma
    908tacoma Well-Known Member
    New Jersey
    2018 MGM
    OME, SPC, TRD
    I was shipped these when my older ones with the zerk fitting failed after about 10k, maybe less.
  6. Apr 19, 2024 at 8:13 PM
    #66
    Stagger Lee
    NorCal
    have they held up okay?
    mine will be here tomorrow and I’ll swap them out Sunday, then get it aligned Monday.
  7. Jun 4, 2024 at 2:39 PM
    #67
    blitzkrieg3002
    blitzkrieg3002 Well-Known Member
    Rick
    California
    2019 Tacoma SR5 4x4
    I'm curious on this as well. My spc ball joints failed around 30k miles.. they will not warranty them. i bought new ball joints and they do not have a zerk fitting. i'm bummed kuz i spent about $100 on a new grease gun and the specific grease they have listed on their website to stay on top of greasing these more often. i emailed spc and they say that they do not reccommend greasing these new ball joints but if you do to use, "green grease" .
  8. Jun 6, 2024 at 9:04 AM
    #68
    Stagger Lee
    NorCal
    yeah, I bought the recommend spec grease too. Already had the gun. I greased them every 5k or so. Not sure why they failed, but they’re trashed. When i pulled them off and rotated them, they’re really rough.
    If this new set does the same, I’ll probably switch to the JBAs and be done with it.
    The swap was a piece of cake, but I’m not stoked on parts failing. Hopefully these new ones hold up.
    I’m not planning on greasing them, as SPC said there’s no need. We’ll see I guess.
  9. Jun 6, 2024 at 9:16 AM
    #69
    Clinch Mountain Preacher
    Clinch Mountain Preacher Serpent handler
    3rd gen AC SR5 4x4
    Tons and tons of folks have had early uca failure with SPC...it's a very known issue.
    They aren't exactly oem quality
  10. Jan 16, 2025 at 6:33 AM
    #70
    DirtTaco
    DirtTaco Well-Known Member
    What other ball joint works with the spc upper control arms that will hold up better? 4000km and mine is shot. Brutal. Highway driving.
  11. Jan 16, 2025 at 8:47 AM
    #71
    Saskabush
    Saskabush Well-Known Member
    Adam
    Saskatchewan, Canada
    2013 TRD Sport
    Elka 2.5" DSC w/ Deaver Stage 1, Archive Hammer Hangers, SPC UCAs, Timbren bumps, TRD baja wheels, 265/75r16 Wildpeak AT4W, Greenlane Sliders, Warn slimline bumper, N-Fab spare tire box mount.
    None, you have to use their ball joints. It's a proprietary design because they are what adjusts the caster and camber. Only 4000km means you just got a defective set (which unfortunately was happening a lot with SPC). Contact SPC and get a replacement under warranty. They have update the design of the ball joints recently which are supposed to last even longer. You will likely get the new ones for replacement.
  12. Jan 17, 2025 at 9:06 AM
    #72
    DirtTaco
    Good to know thank you. I guess I should try to get both of them replaced then.
