SPC UCA Boot leaking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bprout, Oct 24, 2019.
  1. Oct 24, 2019 at 5:55 PM
    bprout
    bprout [OP] Well-Known Member
    Brian
    SoCal
    2014 SR5 4x4
    Runs off Hopes and Dreams
    I have some SPC upper control arms that seem to be leaking (on both sides) after my last alignment :facepalm:(I have had the worst time trying to find someone who can do a correct alignment with these UCAs). I cant seem to find the reason as to why they are leaking though... It also looks like on my driver side the UCA and my coils might be making contact but they are very small scuff marks so i cant be sure...
    From the top looking down:
    Bottom looking up:
    Dead on with the boot:
    Hopefully someone can help, thanks!
  2. Oct 24, 2019 at 7:20 PM
    Pigpen
    Dan
    Northwest Montana
    They're probably leaking due to someone putting in too much grease.
    For your next alignment, set the UCAs yourself. Drive to the shop. Tell them what alignment specs you want. It's that easy.
    bprout[OP] likes this.
  3. Oct 24, 2019 at 7:22 PM
    computeruser6
    computeruser6 Nuclear Janitor
    Dirk
    Escondido
    2008 Regular Cab Tundra
    King 2.5 coilovers Nitto Exo Grapplers
    It's fine, there's nothing wrong with some grease seeping past the boot. The boot doesn't form a tight seal and any extra grease should be able to leave the boot. Just wipe it off and make sure that it's not torn.
    SR-71A and bprout[OP] like this.
  4. Oct 24, 2019 at 7:23 PM
    Pigpen
    Dan
    Northwest Montana
    Oh, and when you schedule the appointment, tell them you'd like them to pull the alignment bolts and coat them with anti seize. They'll need extra time to do this and it will save you about a thousand bucks, if they're not already seized.
  5. Oct 25, 2019 at 6:17 AM
    PoweredBySoy
    PoweredBySoy Well-Known Member
    Jesse
    Minnesota
    2013 DCSB SR5
    I'm on my third set of SPCs and they have always leaked grease out the bottom. Just throw in a couple squirts every oil change. Good to go.
  6. Oct 25, 2019 at 7:56 AM
    bprout
    Brian
    SoCal
    2014 SR5 4x4
    Cool thank you guys! I just wanted to make sure I wasnt going crazy. I wiped them off and they look like the boots are fine so I should be good.
    Im pretty sure when I got my LCA cam gussets welded on he through some anti seize on there already, but next alignment i will definitely ask for some more :thumbsup:
  7. Oct 25, 2019 at 8:15 AM
    12taco12
    12taco12 Well-Known Member
    rochester NY
    2012 TX Pro
    Billy 5100s OME 886 Billy remote resi 5125 rear General hd packs TImbren superbumps/flipkit Pelfrey steel full hoop front SOS bolt on sliders Baja squadron amber fogs Baja 20" bar Aux fuse panel and switches custom 10 sub box double din
    i need to remember this when i install my coopers
    Pigpen[QUOTED] likes this.
