SPC uca from amazon.ca
Discussion in '2nd Gen. Tacomas (2005-2015)' started by garrettmiklautz, Sep 13, 2017.
  1. Sep 26, 2017 at 7:11 AM
    #41
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    It was a joke
  2. Sep 26, 2017 at 7:12 AM
    #42
    Thyces
    Thyces 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    :facepalm:It was 3 am....
  3. Sep 28, 2017 at 12:32 PM
    #43
    garrettmiklautz
    garrettmiklautz [OP] Well-Known Member
    Garrett Miklautz
    2013 Tacoma Double Cab-Super White
    Thinking about doing the uca's this saturday. Does anyone see any issue with me installing these (with the ball joint fully out, and washer set with the spc facing outwards) and not getting an alighment for a while until i get the new coils and struts installs.
    I dont really care about my tires at this point because im due for new ones. But at this setting will it still drive and handle ok without the alighment!?
    Thanks.
  4. Sep 28, 2017 at 1:18 PM
    #44
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    It depends on your current suspension setup but that's what I did about 7k miles ago...still haven't bought tires or gotten an alignment. Set the ball joint in the middle setting (D).
    http://www.spcalignment.com/instructions/25470-INS_WEB.pdf
    If you're planning to install new shocks/springs, why not wait and install the control arms at the same time?
  5. Sep 28, 2017 at 1:35 PM
    #45
    garrettmiklautz
    Garrett Miklautz
    I just figured the arms would be a managable task for the day. And since i dont have the coils yet.
    I just have 5100's on stock coils maxed out at 2.5. Would d be a good setting for now u think?
  6. Sep 28, 2017 at 1:38 PM
    #46
    stickyTaco
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    That should be fine, but again, you're just making more work for yourself since swapping shocks/springs with the UCA off is very easy.
  7. Sep 28, 2017 at 2:00 PM
    #47
    garrettmiklautz
    Garrett Miklautz
    I havnt read much as of yet reguarding coil over installation, but was under the impression the lower control arm needed to be free to get it in. But your absolutely right, if im in there it makes sense to do it at the same time.
    I guess i just figure doing the arms now, its one part down, one to go. Its getting cold here, and not really a project i wanna do in the snow and cold temps as i dont have a garage.
  8. Sep 28, 2017 at 2:01 PM
    #48
    stickyTaco
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    I didn't touch the LCA when installing my suspension.
  9. Sep 28, 2017 at 2:10 PM
    #49
    Canoehead
    Canoehead Well-Known Member
    Duncan
    Dartmouth, NS Canada
    2007 DCSB, lots of scratches
    Rearview mirror upside down
    When you pull things apart to get at your UCA you are halfway through getting the coils out. It is definitely most efficient to do both at the same time, but there is no reason not to do the UCAs first unless you are paying for labour.
    To clarify, you have to remove the strut from the LCA (one bolt), you do not have to disconnect the LCA from anything else.
  10. Sep 28, 2017 at 2:57 PM
    #50
    garrettmiklautz
    Garrett Miklautz
    Ooo ok. Well shit, maybe i should get on ordering those 887's so i can get this done before its -30.
    Is it the same process installing coils if the uca wasnt being swapped?
    I guess what i am asking is there multiple ways to go about installing a coil over on these trucks, or is it one reccomended procedure ?
  11. Sep 28, 2017 at 3:19 PM
    #51
    stickyTaco
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Correct but that's so obvious it shouldn't need clarification and if someone installing shocks can't figure it out without clarification............. :facepalm:
    Some loosen the LCA to get better access but you have to mark the cam bolts to get it all lined back up and make sure the bolts are re-torqued with the vehicle at ride height, otherwise you'll destroy the bushings.
