SPC UCA Grease Question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by keith12, Sep 17, 2024.
  1. Sep 19, 2024 at 12:27 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    JBA HD's here. Can't say enough good things about them. I like that they still use a ball joint but they are beeeef. Much nicer to DD than an option with a uniball, but if you want Uniball then Total Chaos are tried and true.
    Never liked SPC. Usually I get a bunch of hate for saying they suck. Glad others are starting to see that.
  2. Sep 20, 2024 at 8:17 AM
    Sventastic
    Sventastic The more I fix, the more I love this truck. WTF?
    Idaho
    2000 White Tacoma SR5 V6 Manual 4x4
    Old Man Emu Leaf Springs, air intake,
    @JasonLee: Question, can you elaborate for me a bit. I have a some lift on my 1st Gen Taco and I am getting very uneven wear on my tires. I am seeing excessive wear on the inside edge of my tires. To me this indicates that I have negative camber resulting from the lift. My assumption has been that the way to correct this would be to get upper control arms that will be a bit longer and will thus restore the camber to its correct angle.
    Is there something I am missing that might allow me to keep my original UCA's and still get my alignment sorted out so that my tires will wear evenly and my truck will handle properly?
    thanks for any input!
  3. Sep 20, 2024 at 8:24 AM
    Veet-88
    Veet-88 Well-Known Member
    18 Tacoma DCLB sport
    I swapped to dirt kings ball joint arm and have had 0 complaints so far. And I'm about to roll over 2 years with them as opposed to one summer with the spc's
    I havnt had any poor tire wear at a 2" lift. I was able to clear 285's without a chop bit it was tight so I'm assuming these have a bit more caster built in than would be desired for maximum clearence.
  4. Sep 20, 2024 at 8:51 AM
    keith12
    keith12 [OP] Well-Known Member
    Why did you go with the HDs? I'm in my truck for months at a time on dirt and rocky roads, but I try to avoid anything too extreme.
  5. Sep 20, 2024 at 9:29 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    I just like overbuilding stuff and I didn't want to wish I had got something beefier down the line. Plus if there's ever a sweet jump it's 1 less thing to worry about. So far the rest of my suspension has been too good to let me catch any air though, not sure if I'm happy or sad about that lol.
  6. Sep 20, 2024 at 10:00 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    JBAs FTW! No issues with mine after ditching my SPCs. I've had my SPCs listed locally for $175 and can't even get rid of them lol.
    drizzoh likes this.
