SPC UCA install advice
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dlovell90, Jul 26, 2019.
  1. Jul 26, 2019 at 8:48 PM
    Rob Daman
    Rob Daman The Taco Formerly Known as Hard Shell Taco
    Rob
    So Cal
    17 OR 6MT
    a lot
    Post the alignment sheet too so someone could chime in on settings.
    Skydvrr and SpeySquatch like this.
  2. Jul 26, 2019 at 8:49 PM
    Horger12
    Horger12 Well-Known Member
    Albuquerque, NM
    2017 Barcelona Red OR-DCSB
    5100s, Toytec AAL, Falken Wildpeaks, CaliRaised Ditch Pods, BAMF Sliders and Bed Bars
  3. Jul 26, 2019 at 8:53 PM
    dlovell90
    dlovell90 [OP] New build 5/1/19
    Derrick
    Waukee, IA
    2016 Tacoma TRD Off Road
    Billie 5100s OME 888s Fallen Wildpeaks Mamba m25s Lots of cosmetics MESO everything
    Good idea. I’ll have to grab that Monday when I go back though.
  4. Jul 26, 2019 at 8:57 PM
    SpeySquatch
    2016 TRD OR DCSB
    Ahhh then it looks like you are missing the rectangular plate under your round washer under the large cap nut. Unless it’s a new design....?
    Camber on mine is 0.15 degrees and caster is 2.89 degrees
  5. Jul 26, 2019 at 9:05 PM
    dlovell90
    Derrick
    Waukee, IA
    I honestly couldn’t tell you on design. Let’s hope I’m not missing anything!
    SpeySquatch[QUOTED] likes this.
  6. Jul 26, 2019 at 9:19 PM
    SpeySquatch
    2016 TRD OR DCSB
    I am seriously not trying to cause you any worry. The part numbers are right.
    Just weird that it looks like you are missing something.
    Your pic
    How it use to look (my pic)
  7. Jul 26, 2019 at 9:22 PM
    dlovell90
    Derrick
    Waukee, IA
    It looks like mine is so different because the plate and bolt are aligned different. I think it need to be scooted back as someone mentioned.
  8. Jul 26, 2019 at 9:23 PM
    medic2230
    Murph
    Bama! Roll Tide
    Yours do need to be slid all the way out.
  9. Jul 26, 2019 at 9:32 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    You're talking about the square plate underneath that indexes the ball joint at different offsets?
  10. Jul 26, 2019 at 9:38 PM
    medic2230
    Murph
    Bama! Roll Tide
    Also I’m not sure if they ever corrected it in the install paperwork but when you have them slide that out make sure it’s torqued to 150 ft/lbs. the paperwork stated a lower torque on them.
  11. Jul 26, 2019 at 9:41 PM
    dlovell90
    Derrick
    Waukee, IA
    Yea that pound rating isnwhats in the paperwork so they must of updated
    medic2230[QUOTED] likes this.
  12. Jul 26, 2019 at 9:42 PM
    medic2230
    Murph
    Bama! Roll Tide
    Good deal. Glad they finally fixed it.
  13. Jul 26, 2019 at 9:44 PM
    SpeySquatch
    2016 TRD OR DCSB
    No. My bad, he’s right. The angle was playing tricks on me
  14. Jul 26, 2019 at 9:45 PM
    SpeySquatch
    2016 TRD OR DCSB
    I used a 4 ft steel pipe and a torque wrench to break the nut free. Tightening to 150ft-lbs wasn’t the hard part
  15. Jul 26, 2019 at 9:45 PM
    #35
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    I think u have your ball joints rotated 180 out from the 0 degree setting. That’s why most people have the but almost all the way to the outside while yours being all the way in is still not enough to get the tires at 0 degree camber
    SpeySquatch likes this.
  16. Jul 26, 2019 at 9:47 PM
    #36
    medic2230
    Murph
    Bama! Roll Tide
    Also I had one of my UCA bolts work loose one time so every once in a while take a look up there and make sure they are tight. I heard a noise and found it.
  17. Jul 26, 2019 at 9:48 PM
    #37
    medic2230
    Murph
    Bama! Roll Tide
    Might be time for arm day. :rolleyes:
  18. Jul 26, 2019 at 9:48 PM
    #38
    wrmathis
    Bonaire, GA
    parts and stuff
    Looking at yours you have the rounded part facing out
    While this one, which is correct has the flat part out and the rounded part torward the inside
  19. Jul 26, 2019 at 9:53 PM
    #39
    SpeySquatch
    2016 TRD OR DCSB
    couldn’t get leverage to break the nut free, not tighten. Tightening was easy.
  20. Jul 26, 2019 at 9:56 PM
    #40
    medic2230
    Murph
    Bama! Roll Tide
    Ahh gotcha.
