Spc upper control arms are they worth it?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Lopez6895, Nov 9, 2020.
  1. May 10, 2024 at 12:12 PM
    #41
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Aftermarket UCAs are not necessarily when doing a drop bracket lift because your IFS ride height is not changed. A drop bracket lift is basically a spacer between your suspension and the frame. The suspension stays the same but the frame goes up. This is a slight simplification.
    If you were to combine your drop bracket life with a pair of top hat spacers or increased ride height coilovers, then you might need high caster UCAs to get your alignment into spec.
  2. Aug 11, 2024 at 7:53 AM
    #42
    YE2KA
    YE2KA Well-Known Member
    JB
    19 Cement Grey Tacoma Offroad
    What did you think of the SPCs?
  3. Aug 11, 2024 at 7:54 AM
    #43
    YE2KA
    JB
    Did you ever replace the ball joints
