SPC Upper Control Arms?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 71tattooguy, Oct 8, 2020.
  1. Mar 12, 2022 at 7:24 PM
    #41
    71tattooguy
    71tattooguy [OP] Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    Holding up great on mine.
  2. May 18, 2024 at 4:35 PM
    #42
    blitzkrieg3002
    blitzkrieg3002 Well-Known Member
    Rick
    California
    2019 Tacoma SR5 4x4
    My SPC UCA ball joints are failing. installed back in 2020. They've been on for about 4 years and 40,000 miles. about 95% on road 5% offroad miles. Here's a link to the video of me testing them today. Anyone else having such early failure of these ball joints? i grease them every 5,000 - 10,000 miles. Both are shot like in this video. https://www.youtube.com/shorts/2tbTccQt_Es?si=OZaW2PIUROiGustH
  3. May 19, 2024 at 7:44 AM
    #43
    71tattooguy
    Dino
    Petaluma , Ca (707)
    I’ve since moved on with whole set up. SPC’s are gone and will never look back.
    Good luck
  4. May 19, 2024 at 7:53 AM
    #44
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    SPC is working on new ball joints since their old ones weren't the most reliable. I'd assume by the end of the year?
  5. May 19, 2024 at 8:34 AM
    #45
    Clinch Mountain Preacher
    Clinch Mountain Preacher Serpent handler
    3rd gen AC SR5 4x4
    SPC is just okay, nothing more
  6. May 19, 2024 at 10:50 AM
    #46
    blitzkrieg3002
    Rick
    California
    2019 Tacoma SR5 4x4
    I'm pretty astonished that such a critical component has failed so quickly. I really like the control arm for its added alignment ability which is why I bought it. But this is a safety concern now.
    tacoma_ca and 71tattooguy[OP] like this.
  7. May 19, 2024 at 11:54 AM
    #47
    SnuggleTruck
    SnuggleTruck Well-Known Member
    Alex
    Fort Myers
    2020 DCLB TRD OR
    TRD 2" lift shocks Icon AAL (gave me 1" lift with OL leaf out) 17x8.5" -12mm Trail Edition OEM replica wheels by FSW BF Goodrich KO2s (285 70 17) ECGS bushing OME carrier bearing drop kit TRD Pro skid plate Truxedo roll up Tonneau cover MESO - led interior light kit, blackout kit and gashole Toyota door sill protectors and bed mat
    What did you move to?
  8. May 19, 2024 at 12:19 PM
    #48
    71tattooguy
    Dino
    Petaluma , Ca (707)
    I’m on extended travel Kings with dirt King UCA’s. Super happy
    SnuggleTruck[QUOTED] likes this.
  9. May 20, 2024 at 8:46 AM
    #49
    blitzkrieg3002
    Rick
    California
    2019 Tacoma SR5 4x4
    I contacted SPC about the ball joint failure. They have been 0 help so far. I asked the question regarding the early failure of both ball joints and if they think this is the normal lifespan of their product and they have been crickets so far... I cannot recommend these A - Arms given my experience.
    71tattooguy[OP] likes this.
  10. May 20, 2024 at 8:49 AM
    #50
    aturk
    aturk Well-Known Member
    Tony
    Charlotte, NC
    The SPC's are great for their adjustability but both the x-axis joints and ball joints fail wayyyy too prematurely. I went through 3 pairs before I gave up.
    Plenty of posts about it.
  11. May 20, 2024 at 8:50 AM
    #51
    blitzkrieg3002
    Rick
    California
    2019 Tacoma SR5 4x4
    what did you move to? I may be in the same boat.
  12. May 20, 2024 at 8:53 AM
    #52
    aturk
    Tony
    Charlotte, NC
    Accutune arms. Expensive, but have been on the truck for a year and 20k without issue. I was blowing through SPC's in less than 10k.
    Downside is the non-adjustability, when I first put them on I was 34's with a CMR and stock size fenders and most of the plastic fender liner in place. Unfortunately I probably lost 3/8th's of clearance or so, which was just enough to rub the lower lip of the plastic fender liner/fender. So I went to the c4 fender liner kit. Gained a ton of clearance so then I moved from 34's to 35's. No rubbing on anything anymore.
  13. May 20, 2024 at 9:01 AM
    #53
    blitzkrieg3002
    Rick
    California
    2019 Tacoma SR5 4x4
    Great info. Yea i'm very nervous about these SPC's honestly. I have a family trip leaving this wed. was not able to source replacement joints in time after discovering the failure. got me feeling very nervous driving this truck waiting for my wheel to fall off around every corner with my kids in the vehicle with me. esp since i'm loaded down with a FWC and tons of gear. Deff going to be doing some research on what to move to next. Not a good feeling.
  14. Jun 4, 2024 at 1:08 PM
    #54
    blitzkrieg3002
    Rick
    California
    2019 Tacoma SR5 4x4
    So I got my replacement ball joint for the SPC UCA. And looking at it, they now ship a "maintenance free upgraded" ball joint. It doesn't have a grease fitting up top but is instead capped off.
    Has anyone had experience with this "maintenance free" ball joint and getting better life from it? Seems like a step backwards to not allow it to be greasable. Although I'm wondering if I could just simply remove this plug and add a grease fitting.
    http://www.spcalignment.com/images/pdfs/SPC_New_BallJoint_Flyer_0723.pdf
  15. Jun 4, 2024 at 1:23 PM
    #55
    Sungod
    Sungod Well-Known Member
    St Augustine
    The fact that you can still get a zerk fitting and a boot doesn't give me a lot of confidence that they are truly sealed.
  16. Jun 4, 2024 at 2:28 PM
    #56
    blitzkrieg3002
    Rick
    California
    2019 Tacoma SR5 4x4
    I purposely bought a new grease gun and the grease on their website that they recommend. Now this guy on email is telling me to only use "green grease" if I do decide to grease it. But that he doesn't recommend greasing it at all. I pulled the Allen cap on this sealed ball joint and there's white grease inside not green grease. I really dunno what's going on with these things lol
